Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Not a strange problem really I'm sure. I just don't know how to get out of
it
I run 98se and have 2 hard drives. I decided to install Win2000 on my second
drive to see how it was then decided against using it. During installation I
requested NTFS. Having abandoned this project I am now back with my original
98se installation and the second drive ( ex win2000 ) is installed and can
be seen during post etc... but I cannot "see" it from win98se ( presumably
because of NTFS ) How do I get to the drive to reformat it as FAT32 ??
Hope this makes sense - any help greatly appreciated.
"joe" <joe@jj.com> wrote in message news6ndha$7pv$1@ctb-nnrp2.saix.net...
second
I
original
1. Use Win2K FDISK to remove partition(s).
2. Use Win98 FDISK to create and format partition(s).
Don Phillipson
Carlsbad Springs
(Ottawa, Canada)
Thanks Don
Small problem. I can no longer get into Win2000, can that FDISK be
extracted from the CD ?
Thanx for your help
"Don Phillipson" <d.phillipson@ttrryytteell.com> wrote in message
newsD08G5gXFHA.1796@TK2MSFTNGP15.phx.gbl...
> second
installation
> I
> original
can
presumably
> Don Phillipson
> Carlsbad Springs
> (Ottawa, Canada)
Sorry Don
After doing some more exploring ( I am not very adept at this sort of
thing ) I found the following option in win98 FDISK
Change Current fixed Drive
When I selected this I could suddenly see the ntfs partition and was able to
delete and rebuild etc....
Sorry for the confusion, maybe other inexperienced users can learn from
this.
Thanx again
J
"joe" <joe@jj.com> wrote in message news6nh84$fdn$1@ctb-nnrp2.saix.net...
> Thanks Don
> Thanx for your help
> > second
> installation
> > I
> > original
> can
> presumably
> > Don Phillipson
> > Carlsbad Springs
> > (Ottawa, Canada)
_generally speaking_..
Boot with a win98 DOS startup floppy and run fdisk, saying "yes" to "large disk
support". Select the 2nd drive and delete the "non-dos" partition.
Create an extended partition in its place. Create a "logical" within that.
Exit fdisk, reboot and format the drive from windows explorer.
I don't know the exact syntax of any of these steps, as I seldom
use fdisk, but that should give you the general idea.
> Thanks Don
> Thanx for your help
>> second
> installation
>> I
>> original
> can
> presumably
>> Don Phillipson
>> Carlsbad Springs
>> (Ottawa, Canada)
> Thanks Don
> Thanx for your help
>> second
> installation
>> I
>> original
> can
> presumably
>> Don Phillipson
>> Carlsbad Springs
>> (Ottawa, Canada)
"Bill Blanton" <bblanton@REMOVEmagicnet.net> wrote in message
news:e5isUEjXFHA.2684@TK2MSFTNGP09.phx.gbl...
> disk
There really isn't any once you enter FDISK. Choices in fdisk are made by
selecting #'s and pressing Enter other than giving the volume a name, which of
course is typed in. Once finished with fdisk, simply reboot and then format or
press ESC to back out to the DOS prompt.
