Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > PSP----- Power- Supply- Problem
Forum CPU & Components : Power Supplies, Cases & Mods PSP----- Power- Supply- Problem
Hi guys.... ive tried and tried and on my power supply it doesnt tell you anything about the maximum power that can be supplied eg 300W etc.
Is there any program tht can allow me to test or display my power supplies info. I need this cuz i need to buy a new video card and i need to know if it is suitable for my power supply. I want to buy a gigabyte 7900 GTX.
Can ne1 plz recommend a good power supply to buy and what is the recommended power supply for th is card.
Reply to zeeinc
have you tried removing it and looking at the hidden sides?
For your 3.4 (prescott?) / 1g (2 x 512m?) / 6800gt / 2xhdds? / 2xcd/dvd? / 2 x 80mm fan? you are currently around 300w, when you upgrade will be around 335w so if it were me, I would go w/ a 400w minimum.
SPARKLE ATX-400PN-B204 ATX 12V 2.0 400W
+3.3@30A,+5V@28A,+12V1@18A,+12V2@18A,-12V@0.5A,+5VSB@2.0A
$41 shipped @ ewiz
Reply to doolittle
- 0 +
Without removing it, I don't think you'll find any specifications. Since it isn't really linked to the motherboard aside from the power connections, no software tool is going to be able to detect its settings or specs. If you do decide to remove it, make sure you take a long, hard look at where all the little wires run, especially if you haven't installed one before. There can be upwards of a dozen or more connections on more complicted systems.
Reply to bweir
- 0 +
Alright thx for the info!
Reply to zeeinc
There are 2202 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Is my psu sufficient for my pc ?
By rolli59, 2 hours ago:
Yes it can! The only problem is the CM reputation not delivering promised power but you...
Best offers
Top experts
