Hi,
I am having a strange problem. I just installed an new Promise SATA300 TX4 controller in my machine as I did this I also decided to clone my original system drive and put in a new SATA drive instead. I put the new system drive on the MB controller channel 1 since I kept the PATA DVD-burner and HDD on channel 2. I then cloned my old system drive that was located on my other promise controller (Ultra 100 T2). No problems at all doing this. I then restarted the computer and changed the boot sequens in BIOS so that it pointed to the new SATA drive on channel 1 on the MB. This is when the funny things start to happen.
I booted up the machine again with 3 other SATA drives conected to my new controller and the computer just stalls on just before the windows loading screen. I got mad and turned of the last 3 SATA drives and rebooted, Now windows starts as usual.
I then tried to turn on the 3 drives when windows was allready running, and it worked perfectly. I initialize them and formatted them as usual. I then rebooted the system again to see if that helped but I was back to the same problem as before. Fixed it by turning them of and reboot.
So now I can use all my HDDs as long as I remember to turn the 3 new SATA drives of when booting.
My question is: What can be causing this?
Is it conflicts between my old promise controller and my new one?
Is it a bug in the drivers for the new controller?
Any suggestions on what to try?
