I have the ASUS A7N8X mobo. It's worked great for a couple years now.
Recently, my PC has been rebooting spontaneously. I've tracked it down to a heat problem. Each time it's reset, the CPU temp has been about 168F.
The problem is - the heat rises no matter what I do. Lowering ambient room temperature doesn't help (much), taking off the case didn't help, cleaning didn't help. I've turned it on, entered the BIOS to check the CPU temp - and watched it rise from an initial temp of about 90F at a rate of 1 degree a second until it shuts off at 168F.
I checked the heat sink on the chip - it seems to be seated correctly, but I'm enough of a noob that I'm not sure.
Any help?
Any help?
