I just built a new rig for my brother. It comes with an Asus A8N-E motherboard and he gave me a copy of Win XP Pro. The bios recognizes that an ethernet cable is connected to the onboard ethernet, but Windows doesn't and I can't connect to the network to download necessary files and stuff.
Sponsored Links
You need the cd that comes with motherboard and download the appropriate drivers to enable the network hardware of that motherboard.
Reply to chuckshissle
Have you tried device manger? Does it show your network card?
Reply to choknuti
reinstall the drivers for the network card (or install them if you havn't). Window's generic drivers sometimes don't cut it.
Reply to ALL_YOUR_BASE
I have the same mobo and same problem. It connects to the LAN but that's it.
I've loaded the ASUS drivers that came with the mobo, except for the nVidia Firewall stuff.
Rob
Reply to Albireo13
Tom's Hardware > Forum > CPU & Components > Network Interface Cards > Ethernet Help
There are 1032 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
