When attempting to burn data to a DVD using a number of pieces of software, including the 'Sonic MyDVD Pro' bundled with my laptop, the task is performed well seemingly until the DVD is finalised, when an unknown error to do with there not being enough space to store the data occurs.
Specifically, Sonic gives me this error [code:1:5784d13939]Not enough space on the disc
The target disc does not have enough space to store all the information being written to it.
To avoid this error, try one of the following suggestions:[/code:1:5784d13939]
Then lists some things that may be wrong, all of which are inapplicable.
At each instance i have made sure not to exceed the data limit for the DVDs, usually by around 1GB. Additionally, I can rule out the DVDs being faulty due to the same batch working on another computer.
I have a HP Pavillion zd8255ea, with a TSSTcorp CD/DVDW TS-L532M.
Any help or suggestions would be appreciated.
