Motherboard Problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Motherboard Problem
Profile: journeyman
More Information
Okay, I got my DFI UT nF4 Ultra-D working. I haven't put 2 gigs in, only one peice of ram in so far. However, when I try to install windows from my cd, it all goes fine, until I hit the part when then install thing boots from HD and goes to "copying files". THen, it asks me to insert the correct windows xp SP1 cd, which I have in the drive. CAn anyone help me get XP working?
Related Pr oduct
Profile: nimble knuckle
More Information
well if it is a SATA disk you may have to press F6 during the install when it asks you to do so and install the sata drivers.
If you have done that another thing that may help is creating a slipstreamed XP SP2 disk based on your current XP cd which is worth its weight in gold for the system builder since SP2 installation is known to be quirky and the only workaround for those instances.
good luck!
pat
Profile: Forum Veteran
More Information
Quote :
good luck!
Since he has nforce4 chipset motherboard, he DON'T have to do F6. F6 is only for RAID. If RAID is correctly DISABLED in BIOS, then windows will install on SATA hdd just like PATA hdd.
Now, looks like your XP CD is bad. Get one with SP2 already integrated.
Profile: Eternal Poster
More Information
Quote :
good luck!
I agree it sounds like your XP CD or your optical drive is bad.
Get a new one or try Linux :-D
http://mirrors.kernel.org/fedora/c [...] 64-DVD.iso
it's free ;-)
You can always dual boot.
KWH
Profile: member
More Information
Pop a Knoppix disk in and see if that works.
More Information
Profile: journeyman
More Information
Windows works fine, I just don't get the other stuff like Disk Defrag. I tried downloading perfect disk and installing, but I get an error message. I had to enable DHCP to get to the internet. I can't defrag my hard drive =/.
I've tried linux before. Slack, to be exact.
More Information
Quote :
Please run memtest overnight ( 8 - 12 hours ).
http://forumz.tomshardware.com/sof [...] 30767.html
Or if you need to burn it under windows follow these instructions:
Download
http://memtest86.com/memtest86-3.2.iso.zip
http://isorecorder.alexfeinman.com [...] rV2RC1.msi
Unzip memtest86 and record the ISO to a CDR with ISORecorder ( you must have XP SP2 ).
http://isorecorder.alexfeinman.com/HowTo.htm
Good Luck :-D
Profile: Master Historian of THGC
More Information
Defragmenter is in Computer Management under Administrator Tools.
Profile: journeyman
More Information
Quote :
The GUI is there, program is not. As I siad, my windows install was messed up. Got 2 gigs in, and tried out PerfectDisk 7. That doesn't work either, the error message reads something along the lnes of lost connection with PDEngine. I googled the error message, and no solutions were found. MSConfig doesn't work either, btw. Services that are set to automatic don't boot up. Only the vare necessities boot up. No biggie however, just makes my computer run like a dream! When I need to defrag, I'll have to find a cd boot up defragger. Anyone know one of those? I have no floppy drive =(
More Information
Quote :
Upgrade to Linux or BSD and you will never have to defrag :-D
If windows is that messed up you might have other problems.
It is quite possible your install disk is scratched / damaged, your optical drive could be flaky or your hardware might be bad ( RAM, Motherboard, PSU, HDD = suspect ).
Profile: journeyman
More Information
Well, I'm a gamer. Linux doesn't provide the fps i can obtain in Windows. I might set up Arch LInux into a dual-boot sometime, but I honestly don't use it much. Linux is better in every aspect except windows game compatibility. I don't do much networking, a bit of programming, a lot of gaming, and alot of work.
More Information
Quote :
Linux is great for netoworking + programming + work :-D
Unfortunately it is not great for windoze games although native Linux games run very well.
With accellerated drives many games work quite well.
Windoze is better for windoze games with a few exceptions.
I am not sure if you're into some older games but XP broke compatibility with a TON of DOS / Windows games and apps so windoze is not exactly the world's perfect game platform, in fact there is no such thing.
I am still quite concerned about the problems you described, please run memtest overight along with PRIME95.
Profile: journeyman
More Information
Quote :
I don't play old games. I'm playing CSS, DODS, GW, and WoW.
It's just an XP install mess-up. Memory has nothing to do with hard drive defragmentation.
More Information
Quote :
I hope so, I hope it's not something more serious.
Add a reply
Google Ads
News
Volume shipments of G965-based motherboards again delayed
Published on September 05, 2006
Due to a problem with chipset drivers, motherboard makers cannot start shipping products utilizing Intel's G965 Express chipset, sources at Taiwan's motherboard industry indicated. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Acorp to withdraw from motherboard market
Published on March 14, 2005
Second-tier motherboard makers Acorp Electronics will withdraw from the motherboard market and instead migrate into the production of networking devices such as ADSL2+ modems, the company said after a provisional shareholders meeting on Thursday, March 10. Read more
Motherboard shipments expected to decline in November
Published on November 12, 2004
Taiwan's first-tier motherboard makers expect their November motherboard shipments to decline 5 to 10 percent sequentially, as their shipments peaked for the quarter in October, according to sources at the makers. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
