I recently purchased a Thermaltake Soprano and am currently in the process of hooking it up. I've stumbled into a rather confusing problem with hooking up the Front Panel Audio, however.
For the motherboard I have an ASUS A8R32-MVP Deluxe and it mentions two compliant definitions in the manual as follows:
Azalia compliant definition:
(10-1 pin AAFP setup)
ABCDE
FGHIJ
A) GND
B) Presence#
C) SENSE1_RETUR
D) No Pin
E) SENSE2_RETUR
F) PORT1L
G) PORT1R
H) PORT2R
I) SENSE_SEND
J) PORT2L
Legacy AC'97 compliant definition:
A) AGND
B) NC
C) NC
D) No Pin
E) NC
F) MIC_L
G) MIC_R
H) Line Out_R
I) NC
J) Line Out_L
The Thermaltake Soprano labels the connections for the Front Panel Audio as follows:
EAR R
Return R
EAR L
Return L
MIC IN
MIC VCC
Ground
I wish to know which setup I should use and how I should attach each cable to its corresponding pin. Some of them make sense to hook up while others are a bit more confusing. Any help regarding this will be most appreciated.
ABCDE
FGHIJ
A) GND
B) Presence#
C) SENSE1_RETUR
D) No Pin
E) SENSE2_RETUR
F) PORT1L
G) PORT1R
H) PORT2R
I) SENSE_SEND
J) PORT2L
A) AGND
B) NC
C) NC
D) No Pin
E) NC
F) MIC_L
G) MIC_R
H) Line Out_R
I) NC
J) Line Out_L
EAR R
Return R
EAR L
Return L
MIC IN
MIC VCC
Ground
