Yes No
Ads
Tom's Hardware > Forum > Windows 95/98/ME > General Discussion > Communications Port problem
Forum Windows 95/98/ME : General Discussion Communications Port problem
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
When attempting to install a Windows Update (driver update for a modem) for
an eMachines 600Mhz running Windows ME, we think I may have inadvertently
pushed a "yes" button instead of a "no" regarding deleting COM3 at the end
of installation.
The computer is running AOL 8.0, and since downloading this update, there is
no activity from the modem and AOL techs were unable to help.
Could it be possible that the COM port was disabled . . . or whatever? In
the AOL setup info, it says " . . . . modem name . . . on COM 3." However,
in the Device Manager in shows only COM Port 1 and LPT Port 1.
Have no idea what to do next, but our neighbor would very much like to have
his computer fixed. HELP???
Thanks in advance for any advice.
Reply to Anonymous
In Device Manager> Modems, what does it show there?
Is you modem listed, and does it show any errors in Device Status on the General
tab, when you select it and click Properties? On the Modem tab, what port does it
show it is using?
In Control Panel> Modems, is the modem listed on the General tab?
On the Diagnostics tab, is it listed with a com port?
If you select it here and click More Info, do you get an error or a read-out?
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
"Barb" <tincantyps@sbcglobal.net> wrote in message
news:b4Ave.40$j04.24@newssvr21.news.prodigy.com...
> of installation.
Reply to Anonymous
"glee" <glee29@spamindspring.com> wrote in message
news:%23EQ8jumeFHA.2732@TK2MSFTNGP14.phx.gbl...
-- Conexant SoftK56 PCI Modem (M)
> Is your modem listed, and does it show any errors in Device Status on the
> General tab, when you select it and click Properties?
-- No errors shown - "This device is working properly"
On the Modem tab, what port does it show it is using?
-- COM 3
-- Yes
-- Yes COM 3
read-out?
-- Read-out, as follows:
Port Com 3
Interrupt 10
Address 3000
UART: NS16550AN
Highest Speed: 115K Baud
Identifier: CXT\VEN_14F1&DEV_2013+Subsys_8850155D
Comm . . . Response
ATI1 255
ATI2 OK
ATI3 SoftK56V_B2.1_V2.14.06
ATI4 Conexant SoftK56 PCI Modem (M)
ATI5 181
ATI6 SoftK56
CModem Version 11
Rksample Version 341
ATI7 255
AT+FCL . . 0,1
Thanks again for any help.
>> for
>> end
>> of installation.
>> is
>> In
>> However,
>> have
Reply to Anonymous
Well, the modem is recognised, COM3 is present (as a virtual com port of the modem
itself....it won't appear under Ports in Device Manager), and the modem responds
correctly to the terminal request for info.
If you plug a telephone into the "Phone" jack on the modem at the back of the
computer, while the phone line from the wall jack is connected to the "Line" jack on
the modem, do you hear a dial tone when you lift the receiver?
What if any error message are you getting when you try to connect online?
news:O4Eve.92$j04.51@newssvr21.news.prodigy.com...
> -- COM 3
> -- Yes
> -- Yes COM 3
> read-out?
> Port Com 3
> Interrupt 10
> Address 3000
> UART: NS16550AN
> Comm . . . Response
> ATI1 255
> ATI2 OK
> ATI5 181
> ATI6 SoftK56
> CModem Version 11
> ATI7 255
> AT+FCL . . 0,1
> >> for
> >> end
> >> of installation.
> >> is
> >> In
> >> However,
> >> have
Reply to Anonymous
the
> "Line" jack on
-- Yes, there is a dialtone.
-- AOL is the internet provider . . . when signing on, it first says
"Initializing modem, then goes to Dialing "the access number" . . . , but
after a couple of minutes of no activity, a message comes up saying "Modem
cannot establish a connection". We talked with AOL yesterday and they ran
through all their steps; then said we would have to contact the manufacturer
of the computer.
This all started after downloading a Windows Driver Update. There are quite
a few more Windows Updates to be downloaded, however, we can't get it back
online.
Thanks for your time and patience. This computer belongs to a neighbor who
thinks we are really smart about fixing them. We sure hate to disappoint
them. (!)
>> > the
>> -- COM 3
>> -- Yes
>> -- Yes COM 3
>> read-out?
>> Port Com 3
>> Interrupt 10
>> Address 3000
>> UART: NS16550AN
>> Comm . . . Response
>> ATI1 255
>> ATI2 OK
>> ATI5 181
>> ATI6 SoftK56
>> CModem Version 11
>> ATI7 255
>> AT+FCL . . 0,1
>> >> modem)
>> >> for
>> >> inadvertently
>> >> end
>> >> of installation.
>> >> there
>> >> is
>> >> In
>> >> However,
>> >> have
Reply to Anonymous
That Windows Update was a Drivers update, yes? Have you tried
reinstalling the previous drivers from the manufacturer (NOT Windows
Update?) Myself, I'd reboot into Safe Mode, go into Device Manager,
remove *all* COM ports, remove all entries for modem. Then reboot. The
COM ports will reinstall themselves, but you'll have to reinstall the
modem manually--again, use a drivers set from the manufacturer, not the
one from WU. If you can't find a stored copy of the previous drivers
installation, and/or need to verify what make/model of modem, use
Everest.
Finally, go through the process of reconfiguring AOHell to use the
modem. You may even need to uninstall/reinstall.
CAVEAT: I don't work very often with AOHell users, but I suspect that it
installs it's own virtual devices. Check Device Manager carefully for
anything from AOHell and remove it/them in Safe Mode procedure, above.
Also, while you're there, look for any devices that are duplicated,
entries that are obsolete (for devices that are no longer part of the
system). You won't see these entries in Normal Mode, only in Safe Mode.
The rule is "one entry in DM for each device". There may be duplicates
that are normal, especially in the System and USB sections, so the best
procedure is to post back here with a list of duplicated devices, if
any. We can tell you which ones to ignore and which to remove. When you
*do* remove duplicated entries, you need to remove *all* instances and
then let Windows reinstall. You don't know which one is the most current
and correctly configured instance. Also, since many devices are
installed "onto" other devices, you need to remove "Child" devices if
you're removing the "Parent".
Gary S. Terhune
MS MVP Shell/User
http://www.grystmill.com/articles/cleanboot.htm
http://www.grystmill.com/articles/security.htm
news:nuFve.113$j04.44@newssvr21.news.prodigy.com...
> of the
>> "Line" jack on
> online?
> says "Initializing modem, then goes to Dialing "the access number" . .
> . , but after a couple of minutes of no activity, a message comes up
> saying "Modem cannot establish a connection". We talked with AOL
> yesterday and they ran through all their steps; then said we would
> have to contact the manufacturer of the computer.
> quite a few more Windows Updates to be downloaded, however, we can't
> get it back online.
> neighbor who thinks we are really smart about fixing them. We sure
> hate to disappoint them. (!)
>>> > on the
>>> -- COM 3
>>> -- Yes
>>> -- Yes COM 3
>>> read-out?
>>> Port Com 3
>>> Interrupt 10
>>> Address 3000
>>> UART: NS16550AN
>>> Comm . . . Response
>>> ATI1 255
>>> ATI2 OK
>>> ATI5 181
>>> ATI6 SoftK56
>>> CModem Version 11
>>> ATI7 255
>>> AT+FCL . . 0,1
>>> >> modem)
>>> >> for
>>> >> inadvertently
>>> >> at the
>>> >> end
>>> >> of installation.
>>> >> update, there
>>> >> is
>>> >> whatever?
>>> >> In
>>> >> However,
>>> >> like to
>>> >> have
Reply to Anonymous
You took an optional driver by clicking "Driver Updates" in the left
pane at Windows Update? Those are poison to me, & others have also
complained. Hopefully, you may recover with...
"START button, Run, MSInfo32, Tools menu, Update Wizard Uninstall"
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
of
| the
the
| > "Line" jack on
online?
says
but
"Modem
ran
manufacturer
| of the computer.
quite
back
| online.
neighbor who
disappoint
| them. (!)
Status on
| >> > the
| >> -- COM 3
| >> -- Yes
| >> -- Yes COM 3
a
| >> read-out?
| >> Port Com 3
| >> Interrupt 10
| >> Address 3000
| >> UART: NS16550AN
| >> Comm . . . Response
| >> ATI1 255
| >> ATI2 OK
| >> ATI5 181
| >> ATI6 SoftK56
| >> CModem Version 11
| >> ATI7 255
| >> AT+FCL . . 0,1
| >> >> modem)
| >> >> for
| >> >> inadvertently
at the
| >> >> end
| >> >> of installation.
update,
| >> >> there
| >> >> is
whatever?
| >> >> In
3."
| >> >> However,
like to
| >> >> have
Reply to Anonymous
for
> of installation.
is
However,
have
If you didn't disable it, and have recent restore point, try system restore
to a previous time. That will dump the new modem driver.
Nevuh, evuh download, install, or use any hardware driver suggested by
wndows update. I'm not kidding.
Reply to Anonymous
You didn't say what driver you updated from Windows Update. I do not generally
recommend getting drivers from WU, but rather from the manufacturer of the device.
The first thing I would try is what PCR suggested:
Start>Run>MSInfo32> Tools menu> Update Wizard Uninstall, and see if it gives an
option to remove the updated driver.
I just noticed that you said you are running Windows ME....why are you asking this
in a Win98 group? WinME has different features....as Dave mentioned, if you have a
restore point from JUST prior to the problem, use System Restore to restore back to
that.
I suggest you post in the WinME group if you don't resolve it quickly here. I don't
have a WinME machine here to refer to, so I am not sure if there is an option on the
Driver tab of the Modem properties to rollback the driver. The option exists in
WinXP, but I don't know if it was implemented in ME.
> the
> > "Line" jack on
> of the computer.
> online.
> them. (!)
> >> > the
> >> -- COM 3
> >> -- Yes
> >> -- Yes COM 3
> >> read-out?
> >> Port Com 3
> >> Interrupt 10
> >> Address 3000
> >> UART: NS16550AN
> >> Comm . . . Response
> >> ATI1 255
> >> ATI2 OK
> >> ATI5 181
> >> ATI6 SoftK56
> >> CModem Version 11
> >> ATI7 255
> >> AT+FCL . . 0,1
> >> >> modem)
> >> >> for
> >> >> inadvertently
> >> >> end
> >> >> of installation.
> >> >> there
> >> >> is
> >> >> In
> >> >> However,
> >> >> have
Reply to Anonymous
Could still be a fried modem.
Try enstablishing a data connection with something else... like having
another computer act as a dailup server and then dailing to it. If it
doesn't work there's a good possibility the modem is fried (or something
very hidden is wrong).
If the connection works, hit AOL techs on the head with it and send them
to hell.
> of the computer.
> online.
> them. (!)
Model: INFJ
Primary function: Coprocessor
Secondary function: Cluster commander
Yes I'm a therian:
http://www.wikitherian.org
Powered by Deamons(TM).
....to live your life fast
and powerfull; and then
live your life just to keep
the Deamons at bay.
Reply to Anonymous
Once again, Gary, your in-depth instructions have "saved the day." We did
exactly what you outlined. Removed the COM ports and modem (getting into
Safe Mode was tricky - eMachines seems to have a one-second slot of time to
enter this mode through the Ctrl key).
In the meantime, on another computer, we obtained an updated driver .zip
file for the modem.
After shutting down, then starting the computer, let Windows reinstall the
COM ports, pointed to the new driver file for the modem, it installed
beautifully and we have a happy neighbor.
We agree with your opinion of "AOHell", but there is no changing some of the
older ones who don't want to make any changes.
Thank you ALL for your time, advice, patience, and knowledge. We continue
to learn every day from these newsgroups and appreciate so much your
willingness to help.
Enjoy the holiday weekend . . . take some time off for yourselves.
"Gary S. Terhune" <grystnews@mvps.org> wrote in message
news:ucVA1NqeFHA.3880@tk2msftngp13.phx.gbl...
> That Windows Update was a Drivers update, yes? Have you tried reinstalling
> the previous drivers from the manufacturer (NOT Windows Update?) Myself,
> I'd reboot into Safe Mode, go into Device Manager, remove *all* COM ports,
> remove all entries for modem. Then reboot. The COM ports will reinstall
> themselves, but you'll have to reinstall the modem manually--again, use a
> drivers set from the manufacturer, not the one from WU. If you can't find
> a stored copy of the previous drivers installation, and/or need to verify
> what make/model of modem, use Everest.
> Finally, go through the process of reconfiguring AOHell to use the modem.
> procedure is to post back here with a list of duplicated devices, if any.
> We can tell you which ones to ignore and which to remove. When you *do*
> remove duplicated entries, you need to remove *all* instances and then let
> Windows reinstall. You don't know which one is the most current and
> correctly configured instance. Also, since many devices are installed
> "onto" other devices, you need to remove "Child" devices if you're
> Gary S. Terhune
> MS MVP Shell/User
>> the
>>> "Line" jack on
>> "Modem cannot establish a connection". We talked with AOL yesterday and
>> they ran through all their steps; then said we would have to contact the
>> quite a few more Windows Updates to be downloaded, however, we can't get
>> it back online.
>> who thinks we are really smart about fixing them. We sure hate to
>>>> > the
>>>> -- COM 3
>>>> -- Yes
>>>> -- Yes COM 3
>>>> read-out?
>>>> Port Com 3
>>>> Interrupt 10
>>>> Address 3000
>>>> UART: NS16550AN
>>>> Comm . . . Response
>>>> ATI1 255
>>>> ATI2 OK
>>>> ATI5 181
>>>> ATI6 SoftK56
>>>> CModem Version 11
>>>> ATI7 255
>>>> AT+FCL . . 0,1
>>>> >> modem)
>>>> >> for
>>>> >> inadvertently
>>>> >> the
>>>> >> end
>>>> >> of installation.
>>>> >> there
>>>> >> is
>>>> >> whatever?
>>>> >> In
>>>> >> However,
>>>> >> to
>>>> >> have
Reply to Anonymous
news:NGVwe.35311$J12.3827@newssvr14.news.prodigy.com...
to
Run the BIOS Setup and check to see
if there is an adjustable Delay option
which you can increase.
Reply to Anonymous
You are welcome.
PCR
pcrrcp@netzero.net
did
into
time to
..zip
| file for the modem.
the
of the
continue
....snip
Reply to Anonymous
Glad everybody's happy!
There's two ways I deal with systems where it's hard to time the Ctrl or
F8 to catch the Startup menu--often if you hold it down, you get a stuck
key error, but then when that clears you still can't time the hit
right...
Amway, you can run MSCONFIG before trying to reboot to Safe Mode, and in
the Advanced section (button at lower right) that's an option to "Enable
Startup Menu." What that does is add a line to MSDOS.SYS:
BootMenu=1
If you also add this line following the above, you can pretty much leave
it on permanently without it being a nuisance:
BootMenuDelay=3
That overrides the 30-second default delay before Windows continues
booting to the default choice (usually Normal startup.) You can also
change the default startup to something else, like "Logged" by adding:
BootMenuDefault=2 (that's the choice for "Logged" ) The number after the
equal sign refers to the number of the choice as it appears in the
Startup Menu.
Gary S. Terhune
MS MVP Shell/User
> did exactly what you outlined. Removed the COM ports and modem
> (getting into Safe Mode was tricky - eMachines seems to have a
> one-second slot of time to enter this mode through the Ctrl key).
Reply to Anonymous
There are 2183 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need insight on my pc with windows 98 OS
By wombat_tg, 4 days ago:
You will need a dial-up account with an ISP in order to make use to that modem. (You're...
Best offers
Top experts
