Further comments on the IE6 and browseui problem
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I forgot to add this, and I don't think anybody else did, but there is
another small aberration when using IE6 and its browseui DLL files:
When you're in Windows Explorer, and select a folder in the left pane (let's
say, My Documents) so that it opens/expands in the left pane, and then go
over to the right pane to see its contents, that is fine and dandy - BUT..
Close down the Windows Explorer window, and then try Windows Explorer again,
and you have to repeat the whole damn process!
In other words, it doesn't retain focus in the left pane like it should!
(and like it did do, pre IE6).
So cquirke can add that to his tidbits!
34 answers Last reply
More about further comments browseui problem
  1. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    "Bill in Co." <not_really_here@earthlink.net> wrote in message
    news:uI1NPd0eFHA.1448@TK2MSFTNGP14.phx.gbl...
    (let's
    again,
    There is a Registry entry which controls
    how and where Explorer opens.
    Browsing Explorer doesn't change the state of that entry.
  2. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    (let's
    BUT..
    >>again, and you have to repeat the whole damn process!
    I don't know what you're trying to say here: Let me explain:
    I *can* tell you, *unequivocally*, that when I swap out those two browse
    DLLs, everything is fine, and when I put them back, it isn't, in regards to
    THIS issue, and the previous issues already noted. Q.E.D.
  3. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    http://support.microsoft.com/?kbid=130510
    Command-Line Switches for Windows Explorer
    I cannot recall what happened in IE5. In IE6, I doubt I ever saw
    Explorer behave as you wish, to open where it left off! (Maybe fool with
    those command-line switches in the Target field of shortcuts ???) Also,
    clicking the plus sign in the L-pane expands it's sub-folders, but
    doesn't select the folder into the R-pane. Clicking a folder in the
    L-pane will select it into the R-pane, but not expand sub-folders in the
    L-pane.
    Chauvin always did say you'd run into peccadilloes, but ???. Well, you
    haven't exposed yourself to XP again, I hope!
    Thanks or Good Luck,
    There may be humor in this post, and,
    Naturally, you will not sue,
    should things get worse after this,
    PCR
    pcrrcp@netzero.net
    (let's
    go
    BUT..
    again,
    should!
  4. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    You never saw it? Either you were a) blind, or b) possibly have short
    term memory loss. But it's working just great over here, ever since I
    swapped out those two damn DLLs. (but then again, I'm not takin in all
    those daily updates that y'all are so fond of. Go for it, but count me
    out)
    (Maybe fool with
    > L-pane.
    > PCR
    > pcrrcp@netzero.net
    (let's
    BUT..
    again,
  5. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    What are you talking about, Bill? If you open Windows Explorer and then expand a
    particular folder in the left pane and look at its contents in the right pane, and
    then CLOSE Windows Explorer, the next time you open Windows Explorer it does not
    open to the same folder you chose the last time. Press Winkey+E to open Explorer,
    and it will open with My Computer expanded every time, regardless of where you left
    it last time you closed it.
    If you are seeing different behaviour, you are either using a shortcut to open
    Explorer, that is set to open to a particular folder every time, or perhaps you are
    using a third-party utility of some sort to enable this? I have never seen the
    behaviour you describe, even on a clean install on Win98 with no updates.....nor did
    I ever see it in Win95.
    Glen Ventura, MS MVP Shell/User, A+
    http://dts-l.org/goodpost.htm
  6. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    > expand a particular folder in the left pane and look at its contents in
    the
    > right pane, and then CLOSE Windows Explorer, the next time you open
    > Windows
    > Explorer it does not open to the same folder you chose the last time.
    Press
    > Winkey+E to open Explorer, and it will open with My Computer expanded
    > every time, regardless of where you left it last time you closed it.
    open
    Correct. Yes, you're right Glen - I stand corrected. (Apologies to PCR
    too).
    My bad for not remembering that particular detail!
    BUT - even with that shortcut, I get the results I just stated. And I like
    it a LOT better the way it is now, and (I believe) it works the way it is
    supposed to, but ONLY with the DLL swap)
    > or perhaps
    > you are using a third-party utility of some sort to enable this? I have
    > never seen the behaviour you describe, even on a clean install on Win98
    with
    > no updates.....nor did I ever see it in Win95.
    (let's
    BUT..
    >> Close down the Windows Explorer window, and then try Windows Explorer >>
  7. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    news:OBtrrS4eFHA.1400@TK2MSFTNGP15.phx.gbl...
    short
    I
    all
    me
    | out)
    A third possibility is my monitor went black each time I saw it, BUT
    what about Glee? Surely it's more likely for you to be batty than both
    of us!
    | (Maybe fool with
    Also,
    the
    | > L-pane.
    you
    | > PCR
    | > pcrrcp@netzero.net
    is
    pane
    | (let's
    then go
    dandy -
    | BUT..
    Explorer
    | again,
    should!
  8. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    news:%238vZi75eFHA.1328@TK2MSFTNGP12.phx.gbl...
    then
    in
    | the
    | > Windows
    time.
    | Press
    expanded
    shortcut to
    | open
    PCR
    | too).
    like
    is
    OK. If you're happy, I'm happy. But I still don't quite get it. What is
    the shortcut, so I can test it in IE6?
    ....snip
  9. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    the
    >>> Windows
    Press
    to
    >>> open Explorer, that is set to open to a particular folder every time,
    PCR
    >> too). My bad for not remembering that particular detail!
    like
    > ...snip
    This is the shortcut: (adapted from some MS web site article on Windows
    Explorer switches).
    C:\WINDOWS\EXPLORER.EXE /n,/e,C:\
    I always use this shortcut for Explorer to get the left and right panes to
    expand properly (with C: shown in the left pane) and stay that way, meaning
    (since that shortcut is for C:\), THAT is what I want to see in the left
    pane (C:\), whenever I open Explorer using that shortcut. And NOT the
    complete tree showing all the drives on the system, etc, which is more
    inconvenient for me.
    I also have separate shortcuts for D:, E:, and F: Very handy and very
    convenient, if you spend a lot of time in Windows Explorer, which I do
    (messing with files, installing programs, etc).
    But - it won't work right for you!!
  10. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    > is the shortcut, so I can test it in IE6?
    Open Explorer to any folder...
    1. Shortcut
    2. In the shortcut "target"...
    C:\Windows\Explorer.exe /n,/e,path to wherever
    dadiOH
    ____________________________
    dadiOH's dandies v3.06...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
  11. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    > Explorer switches).
    Hi Bill,
    I never use those right panes at all and if ever needed it will just right
    click Explore on whatever Drive or Folder I'm on. I've never made a shortcut
    as you explained.. I just did but I can't get it to do what you have said
    yet although I'm sure it's something I may not being doing as you instructed
    but since I don't use explorer that way though I would of never noticed it
    and so may not be a big focus for me as with the main problems.
    I must of missed your other post recently that you wrote that you wanted to
    add this onto it?
    Rick
  12. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Rick Chauvin wrote:
    >> Explorer switches).
    to
    meaning
    > Hi Bill,
    shortcut
    And you won't be able to get it to work as its supposed to, w/o either
    swapping those two browse DLLs, or going back to IE 55. (Of course, there
    is always the remote possibility that you are still using IE 55, and have
    applied all the "latest and greatest" windows updates, and that killed it
    too, for all I know)
    instructed
    to
    > add this onto it?
    The original post wasn't posted by me, but addressed the problem that
    Windows Explorer had in deleting large numbers of files (this, ever since
    IE6) - it would freeze or hang up for either a few minutes, or indefinitely.
    (Which was totally unacceptable for me).
    And the only "fix" or "solution" was to swap out those two IE6 browse DLL
    files with the older IE55 versions (OR go back to IE55, which would be less
    desireable). Remember?
    > Rick
  13. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Thanks. But I was asking for Colorado's own magical shortcut that..
    still not 100% sure what it does.
    PCR
    pcrrcp@netzero.net
    "dadiOH" <dadiOH@wherever.com> wrote in message
    news:%23lVgjJ9eFHA.1384@TK2MSFTNGP09.phx.gbl...
    | 1. Shortcut
    | dadiOH
  14. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Bill in Co. wrote:
    > Rick Chauvin wrote:
    >>> Explorer switches).
    >>> to expand properly (with C: shown in the left pane) and stay that way,
    >>> meaning (since that shortcut is for C:\), THAT is what I want to see in
    >>> the left pane (C:\), whenever I open Explorer using that shortcut. And
    >>> NOT the complete tree showing all the drives on the system, etc, which
    >>> is more inconvenient for me.
    >> Hi Bill,
    >> shortcut as you explained.. I just did but I can't get it to do what you
    Okay I see, well that issue is a non-use by me so it's small potatoes
    compared to the real issue.
    Both actually <g>
    ...iow, I have the best of any world I want to but at this second it's IE6.0
    SP1 with all the current updates, but any moment I want to all I need to do
    is press 5 in dos to automatically swap back to the 5.5 dlls if I wanted to
    do what you're doing ..but 99.9% of the time lately I leave it current.
    >> instructed but since I don't use explorer that way though I would of
    >> never noticed it and so may not be a big focus for me as with the main
    >> problems.
    >> to add this onto it?
    > indefinitely. (Which was totally unacceptable for me).
    Yes of course I remember <smile>
    Okay thanks, for a moment I was only thinking maybe you had posted something
    since then and that was what you post your 'Subject' was referring too.
    Well all is the same as it was then with the ie6 9x delete hang...
    <shrug> ):
    take care,
    >> Rick
  15. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    I think he just uses:
    or
    C:\WINDOWS\EXPLORER.EXE /n,/e,D:\
    or
    C:\WINDOWS\EXPLORER.EXE /n,/e,E:\
    ...or whatever drive/folder he wants to get to from where he's going using a
    created quickie shortcut there to get right into the Explore menu of where he
    wants. It's just a personal preference ..we all have them..
    I guess I usually just go to MyComputer and click whatever drive I want.
  16. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    news:OQMJOv6eFHA.3160@TK2MSFTNGP09.phx.gbl...
    and then
    contents in
    | the
    open
    | >>> Windows
    time.
    | Press
    expanded
    it.
    shortcut
    | to
    time,
    to
    | PCR
    And I
    | like
    it is
    is
    | > ...snip
    Windows
    | Explorer switches).
    That one (for me in IE6 SP1, fully updated) opens Explorer to C:\,
    expanded one level in the L-pane. That is, all the folders in the top
    level of C:\ are showing, with a plus sign left of the ones that have
    sub-folders. In the R-pane, all the folders & files in the top level of
    C:\ are showing.
    BUT (as you seem to be saying otherwise), ALL OTHER drives &
    psuedo-folders are also there in the L-pane. It is really the same as...
    (a) "WindowsKey+E"
    (b) Click the plus sign left of C:\
    (Expands one level.)
    (c) Click C:\
    (Puts it in R-Pane.)
    And I get the same effect with just "C:\WINDOWS\EXPLORER.EXE". Also...
    (a) "START, Find, F/F, Explorer.scf".
    (Should be in C:\Windows.)
    (b) Copy it to the Desktop or Quick Launch bar.
    It seems to do the same as the others.
    panes to
    meaning
    left
    the
    You DON'T see the other drives in the L-pane??? (You should NEVER have
    exposed yourself to XP that time, Colorado!)
    very
    "C:\WINDOWS\EXPLORER.EXE /n,/e,F:\" or any legit letter does work for
    me!
  17. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    then
    in
    >>>>> the right pane, and then CLOSE Windows Explorer, the next time you
    open
    >>>>> Windows
    >>>>> Press Winkey+E to open Explorer, and it will open with My Computer
    >>>>> expanded every time, regardless of where you left it last time you
    closed
    >>>>> it.
    to
    PCR
    like
    is
    >>> ...snip
    >> Explorer switches).
    > C:\ are showing.
    > (a) "WindowsKey+E"
    > (c) Click C:\
    to
    meaning
    No, they are there, but you have to scroll to see them.
    The point is, I want Windows Explorer to "retain focus" in the left and
    right panes the way *I want it to be* - the way *I set it up to be*.
    > me!
  18. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Those work for me. So does Explorer.scf. But, all drives &
    pseudo-folders (such as a second My Documents) will also show up in the
    L-pane. Remember that day poor old Colorado was toying with XP?
    PCR
    pcrrcp@netzero.net
    "Rick Chauvin" <justask@nospamz.com> wrote in message
    news:%23QotP8BfFHA.2152@TK2MSFTNGP14.phx.gbl...
    | or
    | or
    using a
    where he
    want.
  19. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    > L-pane.
    Me too, just like that, and it seems fine.. I guess.
    Maybe I don't get it, but it seems fine for me.
    I remember he toy'd with lots of different things.. But you have a handle on
    it so I will let you lead.
    nice to say hello to ya,
    bye,
    Rick
    > PCR
    > pcrrcp@netzero.net
    >| or
    >| or
    >| a created quickie shortcut there to get right into the Explore menu of
    >| where he wants. It's just a personal preference ..we all have them..
  20. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Oh!
    C:\WINDOWS\EXPLORER.EXE /n,/e,/root,C:\
    seems to do what he is saying. "/root" seems to eliminate all but the
    root folder & below. It's a little weird, though!
    "C:\WINDOWS\EXPLORER.EXE /n,/e,/root,F:\My Downloads\Microsoft"
    That shows just my Microsoft download folder & below. Geez!
    PCR
    pcrrcp@netzero.net
    "PCR" <pcrrcp@netzero.net> wrote in message
    news:e3rNsECfFHA.2424@TK2MSFTNGP09.phx.gbl...
    the
    | PCR
    | pcrrcp@netzero.net
    that..
    | | or
    | | or
    | using a
    | where he
    | want.
  21. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Regardless of what you do, you STILL have that hangup problem on deleting a
    large number of files, which is totally unacceptable (to me), unless you
    swap out those two DLLs.
    PCR wrote:
    > Oh!
    > PCR
    > pcrrcp@netzero.net
    >> PCR
    >> pcrrcp@netzero.net
    >>> or
    >>> or
    using a
    where
  22. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Yea, OK, nice. But see my update (to myself), before seeing this
    response of yours. "/root" is the thing. Looks weird, though! A guy
    could think his HDD was wiped!
    PCR
    pcrrcp@netzero.net
    news:O$tbmMCfFHA.3124@TK2MSFTNGP12.phx.gbl...
    the
    | > L-pane.
    handle on
    | bye,
    | Rick
    | > PCR
    | > pcrrcp@netzero.net
    that..
    | >| or
    | >| or
    using
    of
    them..
    want.
  23. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Winkey + E et al = WinExplorer with "My Computer" expanded.
    His shortcut = WinExplorer with C: expanded. Saves clicking the + in
    front of C: :)
    dadiOH
  24. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    That's right. It also saves clicking C:\ itself, to put it into the
    R-pane. Try this one, dadiOH...
    I am sure Colorado will take all complaints & lawsuits should you drop
    dead of thinking your HDD was wiped!
    PCR
    pcrrcp@netzero.net
    news:OkkKeTCfFHA.3256@TK2MSFTNGP12.phx.gbl...
    | front of C: :)
    | dadiOH
  25. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    news:eWOLQ9BfFHA.748@tk2msftngp13.phx.gbl...
    ....snip
    Oh! "C:\WINDOWS\EXPLORER.EXE /n,/e,/root,C:\" does that.
  26. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    its great for setting up shortcuts to data folders, though
    C:\WINDOWS\EXPLORER.EXE /n,/e,/root,"C:\web pages\w1\" opens at the folder
    local version of the web site is at, great when editing html files
    Adaware http://www.lavasoft.de
    spybot http://security.kolla.de
    AVG free antivirus http://www.grisoft.com
    Etrust/Vet/CA.online Antivirus scan
    http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
    Panda online AntiVirus scan http://www.pandasoftware.com/ActiveScan/
    Catalog of removal tools (1)
    http://www.pandasoftware.com/download/utilities/
    Catalog of removal tools (2)
    http://www3.ca.com/securityadvisor/newsinfo/collateral.aspx?CID=40387
    Blocking Unwanted Parasites with a Hosts file
    http://mvps.org/winhelp2002/hosts.htm
    links provided as a courtesy, read all instructions on the pages before use
    Grateful thanks to the authors and webmasters
    _
    news:eFlovOCfFHA.3296@TK2MSFTNGP10.phx.gbl...
    | Oh!
    | PCR
    | pcrrcp@netzero.net
    | the
    | | PCR
    | | pcrrcp@netzero.net
    | that..
    | | | or
    | | | or
    | | using a
    | | where he
    | | want.
  27. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    news:eQY8p2CfFHA.584@tk2msftngp13.phx.gbl...
    ....snip
    have
    Try this one, then...
    ....snip
  28. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    I don't need to - no problems over here, remember?
    > ...snip
    > ...snip
  29. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Let's not get vindictive, now!
    PCR
    pcrrcp@netzero.net
    news:%23ZsCp3CfFHA.2484@TK2MSFTNGP15.phx.gbl...
    deleting a
    you
    | PCR wrote:
    | > Oh!
    the
    | > PCR
    | > pcrrcp@netzero.net
    the
    | >> PCR
    | >> pcrrcp@netzero.net
    that..
    | >>> or
    | >>> or
    going
    | using a
    of
    | where
    want.
  30. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Yea, looks like it has it's usefulness. Still, I say, it is weird-- &
    all Colorado's fault!
    PCR
    pcrrcp@netzero.net
    "AlmostBob" <anonymous1@discussions.microsoft.com> wrote in message
    news:eLegxfCfFHA.268@TK2MSFTNGP15.phx.gbl...
    folder
    before use
    | _
    | | Oh!
    the
    | | PCR
    | | pcrrcp@netzero.net
    in
    | | the
    | | | PCR
    | | | pcrrcp@netzero.net
    | | that..
    | | | | or
    | | | | or
    going
    | | | using a
    menu of
    | | | where he
    I
    | | | want.
  31. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Well, OK, then. But stop starting threads about them, then, if you don't
    have any! :-). No, really, try a "/root". Everyone should see it just
    once, but never again after that, with the possible exception of
    AlmostBob.
    PCR
    pcrrcp@netzero.net
    news:uX1EjkGfFHA.3936@TK2MSFTNGP14.phx.gbl...
    | > ...snip
    have
    | > ...snip
  32. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    In my Quick Launch clicking the shortcut to:
    C:\WINDOWS\EXPLORER.SCF
    opens to "c" highlighted and expanded as you describe.
    mae
    "Bill in Co." <not_really_here@earthlink.net> wrote in message news:OQMJOv6eFHA.3160@TK2MSFTNGP09.phx.gbl...
    | > ...snip
    | Explorer switches).
  33. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    try changing the shortcut's target to any of the other possiblities listed,
    this one is good too
    C:\WINDOWS\EXPLORER.EXE /n, /e, ::{450d8fba-ad25-11d0-98a8-0800361b1103}
    opens explorer to the registry setting for the current users 'my documents'
    regardless of what it is
    _
    "mae" <agrannie@notemail.msn.com> wrote in message
    news:OJl2rsKfFHA.484@TK2MSFTNGP14.phx.gbl...
    mae
    | > ...snip
    | Explorer switches).
    meaning
  34. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    No, I like it the way it is - never changed any.
    Quick Launch opens "C" expanded.
    Winkey +E opens "My Computer" or explore when right clicking the icon..
    I have a toolbar for all my other shortcuts.
    mae
    news:OgUzozMfFHA.3124@TK2MSFTNGP12.phx.gbl...
    listed,
    documents'
    use
    | _
    | mae
    | | > ...snip
    | | Explorer switches).
    to
    | meaning
Windows Explorer IE6 Windows
