I've got this power supply.
An allied AL-A350ATX.
Its outputs are: +3.3V@28A;+5V@30A;-5V@0.3A;+12V@15A;-12V@0.8A;+5VSB@2A
I want to upgrade my video card, I'm still sticking with AGP for now, to this card.
evga-GeForce 7800 GS CO SUPERCLOCKED agp.
Now there is a problem... The minimum requirement on that video card is a 350watt power supply with a 12v current rating of 18 amps. If I'm correct, the power supply I have only produces 12v at 15amps.
What would happen if I ran this video card with the power supply I currently have? I do not run any sort of printer/scanner on this computer. I'll run down the specs. This is without my current video card, obviously. Which is an ATI Radeon 9800xt.
3.4ghz Northwood P4 HT
200gig Seagate hard drive, 7200rpm (hard drive cooler as well)
2gig of ram, 4x512, corsair twinx xms.
CDRW/DVD drive
7 case fans.
vantec pci fan card
Sound blaster audigy 2 zs (no front bay)
Now. Second question. If my power supply will not run this video card, could someone refer me to a high quality power supply that will run this and is UNDER a hundred dollars? I'm on a super tight budget.
Thanks in advance!
CDRW/DVD drive
7 case fans.
vantec pci fan card
Thanks in advance!
