G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I've got an old LJ4+ which passes its self test.
I've put an old MIO card in it which I used to use in an LJ4M+.
I've tried to configure the required static IP address through the front
panel, but failed. I can change the address, but the new one doesn't
seem to be retained. Do I need to do something to save it explicitly ?
I also downloaded the JetAdmin software which seems to be a huge
package. This can find the printer if I tell it the MAC address. It
invites me to change the printers IP address, but when I do, it says the
update has failed.
Anybody know how I can set the IP address reliably, or if something here
might need firmware / flash update / be faulty etc ? This is hugely
frustrating !
Many thanks, J/.
John Beardmore
update has failed.
frustrating !
Many thanks, J/.
John Beardmore
