Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I have just updatep my win95 to win98SE. Config and files remain the same.
But win98 Can't detect any USB device (which, btw, never used before in
win95)
There is *nothing* listed for USB Devices in Device Manager? (At bottom
of Device Manger list.)Or is it simply not detecting a USB peripheral
that has been connected to your USB port(s)? If it has detected and
installed a USB Host Controller and a hub (at least one of each), but
you simply aren't seeing the peripheral that's been attached, you need
to detach that device, then install the proper drivers for it, then
reattach the device.
"Vincent" <20@3.com> wrote in message
news:%23e1%23ETFlFHA.2916@TK2MSFTNGP14.phx.gbl...
>same.
> in
> win95)
> Any ideas how to solve this...?
> Thanks in advance
USB controllers are there... and the drivers are installed... (i.e. Vivitar
3615 and Scanjet 4070) but... the devices are not recognized... it just
happens... nothing!
This devices work fine in WinXP on the same machine
Gary S. Terhune <grystnews@mvps.org> escribió en el mensaje de noticias
OVQbnmFlFHA.3300@TK2MSFTNGP15.phx.gbl...
> Gary S. Terhune
> MS MVP Shell/User
> http://www.grystmill.com/articles/cleanboot.htm > http://www.grystmill.com/articles/security.htm >
> >same.
> > in
> > win95)
> > Thanks in advance
I think... that Win95 doesn't recognize USB and as it is an upgrade of
win98...
maybe... that could be the problem?
> Gary S. Terhune
> MS MVP Shell/User
> >same.
> > in
> > win95)
> > Thanks in advance
That may be the problem.
Have you checked the BIOS Setup to see if
there is an option to enable USB
which is currently set to "Disabled" ?
> win95)
> Thanks in advance
I'm fairly certain that if the problem is that USB is disabled in BIOS,
the devices wouldn't show up in Device Manager, at least not without
some alerts.
I'm a bit more certain that after uninstalling them in Safe Mode and
then rebooting to reinstall, they would not be detected. I'm not
absolutely positive, and if anyone has any evidence on the subject I'd
be interested.
Note: I do know that in Windows XP it will detect and install certain
types of hardware even though it's been disabled in BIOS, but I don't
recall that happening in Win9x.
"Hugh Candlin" <No@MeansNo.Com> wrote in message
news:%23IZc2xHlFHA.2920@TK2MSFTNGP14.phx.gbl...
>> same.
>> in
>> win95)
>> Thanks in advance
I'll take a look at the bios too.... thanks..
u1fugMKlFHA.3568@tk2msftngp13.phx.gbl...
> some alerts.
> be interested.
> Gary S. Terhune
> MS MVP Shell/User
> >> same.
> >> in
> >> win95)
> >> Thanks in advance
Note that there might very well be USB items that are disabled in BIOS
relating to something like "Legacy Support"--it's intended to let BIOS
and other OSes access the USB even before Windows drivers are loaded.
USB keyboard/mouse, for instance. Whether or not that is
enabled/disabled shouldn't be a problem, but I'd enable it all anyway,
just in case.
Just wanted you to be forewarned that even if you find some USB disabled
in BIOS, enabling it/them may not change a thing.
news:%23YwQOVKlFHA.1464@TK2MSFTNGP14.phx.gbl...
> noticias
>> BIOS,
>> some alerts.
>> I'd
>> be interested.
>> Gary S. Terhune
>> MS MVP Shell/User
>> http://www.grystmill.com/articles/cleanboot.htm >> http://www.grystmill.com/articles/security.htm >>
>> >> the
>> >> same.
>> >> before
>> >> in
>> >> win95)
>> >> Thanks in advance
Well, my friends... here is it...
still it doesn't work...
There is something like "Enable USB for DOS" What is supposed to be that?
anyway... it was enabled
But.... there was another like "...Thumbdrive.." right below the " USB-DOS"
I enabled it too...
But nothing...
In the Device Manager there are three USB hubs... three USB host
controllers... and one VIA PCI host controller...
There were a non-identified device (yellow icon) I deleted it but it still
doen't recognize the devices...
#lE2DZKlFHA.1044@tk2msftngp13.phx.gbl...
> just in case.
> Gary S. Terhune
> MS MVP Shell/User
> > noticias
> >> BIOS,
> >> some alerts.
> >> I'd
> >> be interested.
> >> Gary S. Terhune
> >> MS MVP Shell/User
> >> http://www.grystmill.com/articles/cleanboot.htm > >> http://www.grystmill.com/articles/security.htm > >>
> >> >> the
> >> >> same.
> >> >> before
> >> >> in
> >> >> win95)
> >> >> Thanks in advance
newsq1I9eKlFHA.2920@TK2MSFTNGP14.phx.gbl...
> that?
> USB-DOS"
> I enabled it too...
> But nothing...
> still
> noticias
>> BIOS
>> BIOS
>> anyway,
>> just in case.
>> disabled
>> Gary S. Terhune
>> MS MVP Shell/User
>> > noticias
>> >> BIOS,
>> >> without
>> >> some alerts.
>> >> and
>> >> I'd
>> >> be interested.
>> >> certain
>> >> don't
>> >> Gary S. Terhune
>> >> MS MVP Shell/User
>> >> http://www.grystmill.com/articles/cleanboot.htm >> >> http://www.grystmill.com/articles/security.htm >> >>
>> >> >> remain
>> >> >> the
>> >> >> same.
>> >> >> before
>> >> >> in
>> >> >> win95)
>> >> >> Thanks in advance
Welll..
It worked..
but... adter deleting all USB controlers (there were no devices) and
reinstalliing them.. again....
with the cam conected and.... turned on...
it installed all the controleers... and... finally detected de "Digital
Camera"
It works fine now...
I havn't test the scanner.. I hope it will work fine too... but let's seee
tomorrow... it's too late now..
the scanner is in the office... At least I can download the pictures
directyl on muy win98 session..
but... tell me.. what was the problem? the drivers seem to be the same....
anyway...
thanks a lot..
O5K6VILlFHA.3260@TK2MSFTNGP10.phx.gbl...
> This is after deleting all USB devices in Safe Mode and reinstalling as
> per my suggestions?
> Gary S. Terhune
> MS MVP Shell/User
> > that?
> > USB-DOS"
> > I enabled it too...
> > But nothing...
> > still
> > noticias
> >> BIOS
> >> BIOS
> >> anyway,
> >> just in case.
> >> disabled
> >> Gary S. Terhune
> >> MS MVP Shell/User
> >> > noticias
> >> >> BIOS,
> >> >> without
> >> >> some alerts.
> >> >> and
> >> >> I'd
> >> >> be interested.
> >> >> certain
> >> >> don't
> >> >> Gary S. Terhune
> >> >> MS MVP Shell/User
> >> >> http://www.grystmill.com/articles/cleanboot.htm > >> >> http://www.grystmill.com/articles/security.htm > >> >>
> >> >> >> remain
> >> >> >> the
> >> >> >> same.
> >> >> >> before
> >> >> >> in
> >> >> >> win95)
> >> >> >> Thanks in advance
When you "install" a hardware device, you aren't just plopping certain
files into certain folders. The procedures include adding many, many
Registry and other configuration file settings, many of which are
variable depending on the existing configuration of all the rest of the
system. Maybe the first install didn't get it right, or if you've
uninstalled/reinstalled/installed other devices, particularly the ones
that the USB (in this example) depend upon--its "parent" devices--it may
have caused the original configuration to no longer be appropriate. Thus
the advice to reinstall.
We use Safe Mode for this purpose primarily so that we are sure to see
all the Registry's list of hardware, since in Normal mode we only see
what's been loaded at startup, not all of the possible installations of
the device that are noted in the Registry. In Safe Mode, you see the
entire list and are more certain of finding all the possible "ghosts".
Your experience isn't the usual one--usually, attaching USB peripherals
is the *last* step in their installation procedures. First make sure
the controllers and hubs are installed, *then* install support software
for the peripheral, then finally attach the peripheral itself. But the
odd machine would be one that always acts as expected. There are always
exceptions around to prove the rules.
news:uf$ylPNlFHA.2852@TK2MSFTNGP15.phx.gbl...
> Welll..
> It worked..
> "Digital
> Camera"
> seee
> directyl on muy win98 session.. >
> same....
> anyway...
> thanks a lot..
> noticias
>> as
>> per my suggestions?
>> Gary S. Terhune
>> MS MVP Shell/User
>> > be
>> > that?
>> > USB-DOS"
>> > I enabled it too...
>> > But nothing...
>> > it
>> > still
>> > noticias
>> >> BIOS
>> >> BIOS
>> >> loaded.
>> >> anyway,
>> >> just in case.
>> >> disabled
>> >> Gary S. Terhune
>> >> MS MVP Shell/User
>> >> > noticias
>> >> >> in
>> >> >> BIOS,
>> >> >> without
>> >> >> some alerts.
>> >> >> Mode
>> >> >> and
>> >> >> not
>> >> >> subject
>> >> >> I'd
>> >> >> be interested.
>> >> >> certain
>> >> >> don't
>> >> >> Gary S. Terhune
>> >> >> MS MVP Shell/User
>> >> >> http://www.grystmill.com/articles/cleanboot.htm >> >> >> http://www.grystmill.com/articles/security.htm >> >> >>
>> >> >> >> remain
>> >> >> >> the
>> >> >> >> same.
>> >> >> >> used
>> >> >> >> before
>> >> >> >> in
>> >> >> >> win95)
>> >> >> >> Thanks in advance
please permit me to use this thread. I have anothr type of problem. My
webcam and a brodband modem are connected to usb. But sometimes the
computer is not able to "detect" the usb and I may not be able to use either
of the two devices. I shutdown (not merely restart) then the computer is
able to detect and everything is ok. USB was installed later.
windows 98SE
the information as in <system information> is given below:
Gary S. Terhune <grystnews@mvps.org> wrote in message
news:#08BlqOlFHA.3544@TK2MSFTNGP15.phx.gbl...
> Gary S. Terhune
> MS MVP Shell/User
