Hi! I have to identical ram cards: 2xcrucial ballistix 6400 1 gb ddr2. Each of them single (1gb) runns great, no errors, memtest ok on both. But when I run them together (2gb) I get blue screens, errors, crashes in windows and games. and memtest errors. I've tryed all slot combinations. Have 4 slots, 2 colors. I've tryed to reset bios. ram volt 2.1 as it says on the mem box. And i've deleted hdd and reinstalled xp, same problem. Why doesn't it work with 2 sticks when they are both running great alone?
Abit ni8 sli
p d 3.0 ghz
x1800xt
windows xp home sp2
I have updated bios. I set volt to 2.2. Memory timings is auto. I put in the other identical mem card. I turn on the computer . Try to play half life. Crashes after 10 sec of playing. NO crashes with only one mem card.
It sounds like a timing problem but it might be a defective motherboard.
Do you have another DDR2 motherboard you can test the memory sticks in?
Maybe you can borrow one from a friend.
Are you certain the sticks are identical?
Are they DDR2-667?
Have you tried to manually set the timings in the BIOS to high values?
Hi! Thanx for the tips! I had alredy tryed sigle channel in dimm 1+2 But now I tryed in dimm 3+4... And it seems to work!!!! Mabye dimm 2 is faultuy? When I try 1+2 it just beeps and nothing comes up... I've only tryes counterstrike, but its working!!! Thanks!!!
