Changing Drive Letter Assignments
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
This has probably been asked a 1000 times...
My old AT PC had a single HDD(C:), a floppy(A:) and a CD-ROM(D:).
I've just added a 2nd HDD and now the drive letters are:-
1st HDD (C:)
2nd HDD (D:)
Floppy (A:)
CD-ROM (E:)
I've just changed the device settings for the CD-ROM to be drive (O:)
for Optical.
I would like to change drive letter assignments for the 2nd HDD to
something like "S:" for Spare, but the device manager letter
assignment box is greyed out so I can't change it. Ditto the "reserved
drive letter" fields.
Is is even possible under Win98? If so, how?
Win98 original, not SE, not ME.
7 answers Last reply
More about changing drive letter assignments
  1. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    "Gary D." <ignore@notvalid.net> wrote in message
    news:bvnrf1hpclti01qaq90qdicg8f8prcs0d4@4ax.com...
    > for Optical.
    The likeliest cause is that Drive D: is Primary DOS, therefore
    automatically assigned the next available drive letter.
    You can use FDISK to wipe D: (wiping all data) then create
    a new partition as Extended DOS and FORMAT it; then
    give it drive letter S:
    Don Phillipson
    Carlsbad Springs
    (Ottawa, Canada)
  2. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    In that the letters are assigned by the system, how would a user assign a
    letter other than by using a third party program such as Letter Assigner?
    Regards
    Ron Badour, MS MVP for W98
    Tips: http://home.satx.rr.com/badour
    Knowledge Base Info:
    http://support.microsoft.com/default.aspx?pr=kbinfo
    "Don Phillipson" <d.phillipson@ttrryytteell.com> wrote in message
    news:e2NMkCAoFHA.2540@TK2MSFTNGP15.phx.gbl...
    >> for Optical.
    > Don Phillipson
    > Carlsbad Springs
    > (Ottawa, Canada)
  3. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Gary D. <ignore@notvalid.net> wrote in
    news:bvnrf1hpclti01qaq90qdicg8f8prcs0d4@4ax.com:
    > 1st HDD (C:)
    > 2nd HDD (D:)
    > Floppy (A:)
    > CD-ROM (E:)
    > for Optical.
    Try 'Letter Assigner'
    <http://www.v72735.f2s.com/LetAssig>
  4. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    If I recall correctly, doesn't Letter Assigner run in the background? If
    so, is it worth another program eating up resources just to change one drive
    letter? A rhetorical question for OP, no response required. :-)
    Regards
    "Ingeborg" <a@b.invalid> wrote in message
    news:Xns96B198A59F673abinvalid@213.132.189.33...
    >> 1st HDD (C:)
    >> 2nd HDD (D:)
    >> Floppy (A:)
    >> CD-ROM (E:)
    >> for Optical.
  5. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    No, does its thing via ini via autoexec.bat at boot time; eg...
    @C:\PROGRA~1\_MYPRO~1\SYSTEM\LETTER~1\LETASSIG.EXE @LETTERS.INI
    /O:DRIVEMAP.DAT /CD
    > If so, is it worth another program eating up resources just to change
    > one drive letter? A rhetorical question for OP, no response
    > required. :-)
    You got one anyway :)
    dadiOH
    ____________________________
    dadiOH's dandies v3.06...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
  6. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    On Sat, 13 Aug 2005 08:49:35 -0500, "Ron Badour" <Sorry@NoAddress.com> wrote:
    Ron, it is not a rhetorical question. :)
    It does not run in the background -- it runs while booting, and then quits.
    It runs also when you launch it to reassign the letters.
    When many years ago I installed this program, tried it an was amazed -- I
    supposed then HOW it works, and asked Vadim by email, am I correct. And got
    the positive in general answer.
    The background of my assumption was that even C letter for the first drive is
    not from God. ;)
    BTW, if I recall correct -- Partition Magic can do that as well. But this
    option was introduced later; besides that PM, is not my choice.
    Mikhail Zhilin
    MS MVP (Windows - Shell/User)
    http://www.aha.ru/~mwz
    Sorry, no technical support by e-mail.
    Please reply to the newsgroups only.
  7. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Thanks Mikhail and DadiIO for the correction. Obviously an advanced case of
    CRS has set in. :-)
    Regards
    "Mikhail Zhilin" <mwz@x.REMOVEx.aha.ru> wrote in message
    news:hl2sf1p1h0v048ca9sepne8ovvlf46vuro@4ax.com...
    >>drive
    > quits.
    > got
    > is
    > not from God. ;)
    > Mikhail Zhilin
CD-Rom Hard Drives Windows
