News
Everlight Claims LED Backlighting In Notebook Applications To Reach 70% By 2011
Published on March 06, 2008
While the penetration rate of 7" LCD panels utilizing LED backlighting will reach 62% in 2008, the penetration rate of notebook panels adopting LED backlighting will only hit 15% this year, but increase to 33% in 2009 and 71% in 2011, according to Robert Yeh, chairman of Everlight Electronics, as cited in today Chinese-language Economic Daily News (EDN) . Read more
Corning says LCD TVs to have 33% penetration rate in 2007
Published on January 26, 2007
During its latest financial announcement, Corning estimated LCD TVs should account or 33% of the global TV market or approximately 68 million units in 2007. Read more
CompactFlash revision 3 increases data transfer rate to 66 MByte/s
Published on September 27, 2004
The CompactFlash standard received an upgrade in its revision 3, boosting the interface data transfer four-fold. The standard now integrates FAT32 to support the full capacity of cards over 2.2 GByte. Read more
Latest Reviews & Articles
Radeon HD 4870 X2: Four Cards Compared
Published on November 19, 2008
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Published on November 18, 2008
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
The Hardware Behind Overdrive
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
How To: Get A 4 GHz Dual-Core For $120
Published on November 17, 2008
Intel’s 45 nm Core 2 serious is known to boast substantial overclocking margins, and the entry-level E7200 with 3 MB L2 cache costs less than $120. We'll show you how to get close to 4 GHz from this little gem. Read more
Rate My system
Word :   Username :
Bottom
Author
 Thread : Rate My system
Profile: stranger
More Information
hi ppl,
I;m putting together a new system i was wondering if u gurus can maybe point out any weaknesses or bottlenecks u'd get from looking at it first glance. I wan tto build this system for optimum speed all without being too pricy.
here goes:
Mobo: Asus P5LD2 S775 i945P DDR2 PCI-E/SATA2/Raid/GLan Full ATX MB
CPU: AMD Athlon 64 3700+ 64-bit 939 pin w/Fan
Ram: 2x SAMSUNG 1GB DDR2 PC2-4200 533Mhz 240PIN
Hard disks: 2 x "Maxtor DiamondMax 10 SATA 2 Festplatte 200 GB 16MB 7200" set with RAID
Graphics: NVIDIA GEFORCE 6800 ULTRA 256MB PCI EXPRESS VIDEO CARD
Your commends are appreciated :)
Related Product
Profile: nimble knuckle
More Information
Well, for starters, I anticipate great difficulties in running a socket 939 Athlon processor in a LGA775 Intel board designed for the Intel P4...
Either change mainboards and memory to accomodate the A64 (a socket 939 NF4 board uses standard 184 pin DDR PC3200, not DDR2), or processors...or both.
The 6800 Ultras are outdated...
Find a 7600GT for $200-ish), or a 7900GT if you can afford the extra $100 (they are about $300) and really like 3d gaming...
Profile: addict
More Information
Well i have an Athlon 3700 and its alright, but something is slowing down my system... Im not an expert or anything but if you havnt orded yet then i suggest you go a bit higher on the CPU. Although theres always a chance that my 3700 is just bottlenecking my system so dont take my word on it alone.
Profile: member
More Information
FYI- the motherboard you have listed is for an Intel CPU not an AMD.
Profile: stranger
More Information
in fact i havent chosen a mobo yet i saw specification for this one which looked ok but missed the amd-intel bit :roll:
Lord of the Duck Clan
Profile: Faithful Poster
More Information
Quote :
hi ppl,
here goes:
If you can make that work, you are an amazing person. lol
Make the follow changes:
Motherboard: Asus A8N-E Socket 939- $89
http://www.newegg.com/Product/Prod [...] 6813131530
RAM- Corsair XMS 2x 1GB DDR-400 - $189 before $50 rebate
http://www.newegg.com/Product/Prod [...] 6820145575
Unless you are doing video editing or something that requires large writes to your drive, RAID is useless and only increases the chances of failure. If either hard drive or the controller fails all your data is gone. Unless you are doing large drive writes the speed gain is an illusion anyway. So if you really need that much space get 1 500GB drive. Like this Segate for under $300:
http://www.newegg.com/Product/Prod [...] 6822148108
As the other poster said also, that video card is long outdated. Pick up a 7600GT or if you are serious about gaming a 7900GT. Here is a good eVGA 7600GT for under $200 with a $10 MIR:
http://www.newegg.com/Product/Prod [...] 6814130283
Hope this helps you.
Profile: old hand
More Information
shadowducks builds looks great
Profile: enthusiast
More Information
go for that pentium D 805 th just reviewed. crank it to 3.5 or 4 GHz and youll be set for cheap
Profile: old hand
More Information
Quote :
.. that is until you get that power bill!
There is ALWAYS a drone.
Profile: Ancient Poster
More Information
I'm also inclined to agree with Shadowduck on all points. You don't need the RAID for gaming, and it isn't worth the extra point of failure. His video card suggestions are also solid.
rHy0, my guess on your "slow" 3700 CPU would be that other processes are running, whether intended or not. If it isn't spyware/adware, it could be a virus scanner (and its updates), firewall, or any number of other programs that like to connect to the net to check for updates (even my Logitech drivers want to do that sometimes).
This is, to me, the number one argument in favor of a dual-core CPU. While games may not yet use them, or not enough to make a difference, all this other stuff DOES make a difference.
Oh yeah, and the comments about the AMD on an Intel mobo were pretty funny.
Profile: enthusiast
More Information
Quote :
.. yeah i suppose :( oh well just run extension cord from neighbors without them knowing
Profile: old hand
More Information
Quote :
Haha! touche'! A point for you.
Google Ads
