Archived from groups: alt.games.microsoft.flight-sim (More info?)
Hi All,
I'm finally just starting to tackle getting used to my CH Pro Throttle,
Pedals, and Fighterstick.
Strewth, more dials, buttons, knobs, hat switches than you can poke a
stick at!
What on earth does everyone use the mini joystick for, on the throttle??
My 'Sim flying is ~ 90% FS9, ~ 5% CFS2 and 3, and ~ 5% IL2 Forgotten
Battles, and so far, I've decided just to program all the assignments (to
the way I fly) in each of the 'Sims.
Is there any advantage to creating Maps, using CH Control Manager?
John;
I didn't even install the CH software for my setup which is exactly the same
as yours. I use the axis and button assignments available in the sim using
the simple direct X available in XP. Less hassles and less potential
conflicts. There's plenty of buttons and hats available without installing
the software.
Many use the CH manager...but in my opinion, the system is more stable
without a third party controller manager installed. This of course is
simply my own personal preference.
Dudley
"John Ward" <johnrmward@optusnet.com.au> wrote in message
news:42f818c8$0$19501$afc38c87@news.optusnet.com.au...
> Hi All,
> stick at!
> throttle??
> Regards,
> John Ward
Hi Dudley,
Well, I bought them on your recommendation, mate!
I agree re the less superfluous "stuff" running, the better, but I
thought I might have been missing some important point.
It's still got me st...'d what everyone uses the mini joystick on the
Throttle for - maybe I need to learn how to fly better, and then it might
dawn on me? :-)
Regards,
John Ward
"Dudley Henriques" <dhenriques@noware .net> wrote in message
news:02VJe.2806$RZ2.1318@newsread3.news.atl.earthlink.net...
> John;
> same as yours. I use the axis and button assignments available in the sim
> using the simple direct X available in XP. Less hassles and less potential
> the software.
> Dudley
>> Hi All,
>> Throttle,
>> stick at!
>> throttle??
>> Regards,
>> John Ward
I don't use it at all John. It's the one thing I can't imagine using in any
normal scenario. I understand that it can be programmed in the sim using the
CH manager, but I haven't looked for or found a use for it yet :-))
D
news:42f81f38$0$1909$afc38c87@news.optusnet.com.au...
> Hi Dudley,
> dawn on me? :-)
> Regards,
> John Ward
>> John;
>> potential conflicts. There's plenty of buttons and hats available without
>> installing the software.
>> Dudley
>>> Hi All,
>>> Throttle,
>>> stick at!
>>> throttle??
>>> (to
>>> Regards,
>>> John Ward
O.K., I'll forget about it.
Thanks again.
JW
news:wiVJe.3011$Je.2619@newsread2.news.atl.earthlink.net...
>the CH manager, but I haven't looked for or found a use for it yet :-))
> D
>> Hi Dudley,
>> dawn on me? :-)
>> Regards,
>> John Ward
>>> John;
>>> sim using the simple direct X available in XP. Less hassles and less
>>> without installing the software.
>>> Dudley
>>>> Hi All,
>>>> Throttle,
>>>> a
>>>> stick at!
>>>> throttle??
>>>> (to
>>>> Regards,
>>>> John Ward
On Tue, 9 Aug 2005 13:13:00 +1000, "John Ward"
> dawn on me? :-)
Probably the most common use is as a mouse. You can set it up to move
the cursor, set one of the buttons as the left mouse button and you
don't need to use the real mouse. In FS it also seems to be possible
to tune the radios with the mouse Z axis. Probably the only other
direct use in FS would be as a rudder axis if you didn't have pedals.
You can program it to send characters too, though, so you can set it
up to control zoom in and out, things like that, if you want to.
John Ward wrote:
> Hi All,
> Throttle, Pedals, and Fighterstick.
> poke a stick at!
> throttle??
Strewth mate, if ya flew something that blew hot air out the back you'd find
a use for that lil joystick. I had the Thrustmaster setup many years back,
and as I recall (sold it when I discovered I had as much talent flying a
F-16 in combat as maybe doing aerobatics in the space shuttle) it was used
for things like target aquistion on the radar, and kewl stuff like that, and
also served as a mouse.......
Hi Bob Church,
Thanks for that, mate.
"Probably the most common use is as a mouse. You can set it up to move
the cursor, set one of the buttons as the left mouse button and you don't
need to use the real mouse."
AHA - I've been trying to find a way to do just that!
Do I need to use CH Control Manager/Maps to do that, or just find the
right assignments within the 'Sim?
Regards,
John Ward
"Bob Church" <sticky_NO_@_SPAM_stickworks.com> wrote in message
news:42f88164.1962602@netnews.worldnet.att.net...
>> dawn on me? :-)
> Best regards,
> - Bob
> The StickWorks
> http://www.stickworks.com
Hi CRaSH,
Quitter! :-))
"...and also served as a mouse......."
That's two votes for that - seems to be the way to go.
Geeze, you almost have to be a contortionist to use all these things at
the same time (that's going to be my excuse, anyway)! :-))
Regards,
John Ward
"CRaSH" <sorry@aint-here.spam.com> wrote in message
news:7L8Ke.302951$Qo.133108@fed1read01...
> John Ward wrote:
>> Hi All,
>> poke a stick at!
>> throttle??
> find a use for that lil joystick. I had the Thrustmaster setup many years
> back, and as I recall (sold it when I discovered I had as much talent
> flying a F-16 in combat as maybe doing aerobatics in the space shuttle) it
> was used for things like target aquistion on the radar, and kewl stuff
> like that, and also served as a mouse.......
> things at the same time (that's going to be my excuse, anyway)! :-))
On Thu, 11 Aug 2005 06:44:44 +1000, "John Ward"
Hi John,
You're quite welcome!
Yes, you do need the Control Manager to do it. Then you just assign
the X and Y axes on the Pro Throttle to the X and Y axes on the Mouse
in the map. Some sims may allow for some other centering axis
functions, I know when I first saw the Pro Throttle back in 2000 they
had one set up in Warbirds(?) to control view direction. Continuous
panning up/down and left/right from inside the cockpit. If you run a
map you can also use it to send characters, turn it into an 8-way hat,
use it to set trim or zoom, lots of possibilities. It's just that
there aren't many centering-axis functions in Flight Sim that will use
it directly.
Hi Bob Church,
Thanks for that - much appreciated.
I'll experiment with Control Manager.
Warbirds was the first 'Sim I noticed, after getting interested ~ 4
years ago, that had a "lighted" night environment....
I'm looking forward to seeing how Battle of Britain II is - paid for it
in advance ~ 2 months ago!
Regards,
John Ward
news:42fbf0b7.10971618@netnews.worldnet.att.net...
> Hi John,
> it directly.
> Best regards,
> - Bob
> The StickWorks
