Sapphire Ati radeon 9600Pro 128MB DDR
May 11, 2006 11:19:32 PM
Hi, i need to know the limits in overclocking this card because i want a little bit more graphic power without upgrade. Def. clocks are GPU 400MHz, MEM 600MHz, core is RV350.
May 12, 2006 12:04:46 AM
If you really want to push it, a volt modded 9600 can make 600mhz core,
plenty of people on the ORB have done it.
You want to be safe? Just find a decent cooling solution, download the latest version of ATI tool and let it do the work for you.
May 12, 2006 1:19:35 AM
You were right Raven. I downloaded latest ATI Tool, heatsink i made myself and mounted two 5cm coolers from my old P2 rig and result is GPU 525, MEM 700.
That`s great result for me!!!
May 12, 2006 1:29:28 AM
Did you make any voltage or memory adjustments?
EDIT: Thats good news so far, I'm sure you can get it further though :twisted:
