News
Crysis Warhead $699 Gaming PC from EA Details
EA has released the final specifications of its specialized “Crysis” machine that it intends to offer for those looking to get into PC gaming’s most demanding title. Read more
Forget DVI, HDMI; USB Displays Coming
We look at DisplayLink, a USB-based multi-monitor solution. Read more
AMD Unleashes the Dragon
Consumers looking for elite-level computing branded with a low-end price tag should look no further, as AMD today launched its "dragon" platform technology featuring the new AMD Phenom II X4 processor. Read more
BioHazard CEO: "Skulltrail Is Overkill For Current Games"
Interview - If you are looking into the ultimate PC platform there, there's little that can touch an Intel Skulltrail in terms of performance, price and bragging rights. Read more
Latest Reviews & Articles
Cryostasis: From Russia, With An Appetite For Fast Hardware
We recently had the chance to play a bit of Cryostasis, the latest title supporting Nvidia's PhysX technology. In fact, we played the game on five different hardware configurations. Want to play this one? We'll tell you what you need in order to enjoy it. Read more
Hard Drives, Yesterday And Today: From 500 GB To 1.5 TB
Hard drive capacities have increased in large increments over the last few years, while trends indicate reduced spindle speeds of 5,400 RPM instead of 7,200. We looked at three generations of Samsung hard drives to analyze the performance ramifications. Read more
Best Graphics Cards For The Money: June '09
This month, ATI's new Radeon HD 4770 is missing in action, since online stores are not only unable to keep it in stock, but also de-listing it completely. With violent movements in pricing, though, it'd have been taken off the recommended list anyway. Read more
Editor's Corner: Nvidia’s Ion Revisited, 7.1 Ch. LPCM Fixed
Nvidia's Ion for the do-it-yourselfer launched last month in the form of Zotac's mini-ITX motherboard. Though sexy in principle, the platform had some teething pains right out of the gate. Chris Angelini revisits those issues and uses Ion as a real HTPC. Read more
All the Reviews & Articles
Tom's Hardware > Forum > CPU & Components > Other Components > Recommended Monitor for CAD work
Would LCDs (in the $300 price range) be okay for CAD work or is the performance of CRT a must?
Thanks in advance.
Sponsored Links
I work on a CAD workstation 6 to 8 hrs a day. To me a high end LCD is mandatory, or else get someone else to stare all day at a crappy workstation.
I use a Dell 2405FPW, and it is ideal, and a 21" LCD is a minimum spec, imo.
Reply to RichPLS
There are only two reasons I know of to avoid LCDs. High response times (ghosting) and bad color. CAD work doesn't have fast movement, so no problems with ghosting. I don't believe you would have any problems with accurate color either. (You only need to tell the difference between red and orange, not red and magenta.) Depending on sales, if the large screen LCDs are too much, I would get a couple of 17/19" I would probably go this route anyways. CAD work is easier on a dual monitor setup...
Reply to 4745454b
I have previosly worked with autocad and I really can't see how a crt could be better than a lcd. The lcd has a clearer picture since it can't be out of focus as crt's somtimes are. The lct is also easier on the eyes since it doesn't flicker like crt.
I would recomend that you get as large monitor as possible and don't buy a high prized smaller monitor.
Reply to M_with_one_M
- 0 +
LCD is far much better than any CRT monitor for CAD, and the larger the better. Don't take me and my 15 years CAD engineering experience, ask any CAD operator.
Also, a 19" CRT is small for CAD design, generally considered entry level.
Like I said, CAD workstations make money, skip and you lose productivity and motivation. Bigger is better with CAD displays.
Reply to RichPLS
Not sure why people seem to miss what I said. Buy two smaller displays! Multi monitor is better then single large monitor. I'm sure you could buy two 17" LCDs for the same price as a large one. If your into treating yourself, two 19" LCDs would be perfect. (two 21"s would be best, but not everyone can afford this...) I'm not sure what a large monitor costs, but two of these are only $540. http://www.newegg.com/Product/Prod [...] 6824116375
This will give you two 19" LCD monitors again, for less then $550 shipped. Cheap 20"s seem to be arround $475, while 23" LCDs start at $920. Again, I'd rather spend the extra $75 and get the two 19" LCDs, way more pixels...
Reply to 4745454b
- 0 +
I used to use a 21" and a 19" for CAD, but found it more efficient to have a larger single LCD since it is easier on the eyes and a second monitor does not help that much anymore.
In the old days, a color monitor and a monochrome monitor were referred, with the text window on the mono display.
Using two displays today the same second display is used for text, the main one for graphics.
Two monitors does not negate one bit having at least one large LCD, the second monitor can be even a 15" CRT, since it only needs to display a text window.
Reply to RichPLS
I Agree.
Best one big monitor than two little. Minimun CAD monitor 20" 1600x1200. Little second monitor is useful to show text and palettes (like properties etc) and web (loking specs of things you are drawing etc)
Reply to Topota_madre
- 0 +
I use a sony sdm-p234 (23" 1920 x 1200) for CAD work like solidworks and visio. I think a single large format display is easier to use than two 19/17" LCD. The Dell 24" and 30" are also ideal. Quite an investment though.
Reply to Thorax
There are 788 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
