memory problem
Forum Motherboards & Memory : Memory - memory problem
I have an Asus A7N8X-E wian an AMD Sempron (barton) 3000+ and 3x512Mb Kingston PC3200.
the problem I have is the following, I can run the memory at 173 Mhz maximum, if I try anything more, the memtest will give me an error from test 7 to the end.
I've tried to loose the timings, but I can't achieve the 200 Mhz
Can anyone tell me why this is happening? I mean PC3200 means 200 Mhz, why can't I achieve it?
Sponsored Links
Maybe because you have sync FSB - RAM... If you have a 333 MHz FSB (166 DDR), which I think you have, your memory will run at 333 MHz.
Maybe when you increase the memory's clock you're also increasing CPU's clock.
Watch out for that. I hope this helps! :)
Reply to Multiplectic
Tom's Hardware > Forum > Motherboards & Memory > Memory > memory problem
There are 1173 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
