Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Possible problems with Silverstone ST60F
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Possible problems with Silverstone ST60F
This is the 600 watt unit. When I first built my new system 3 months ago I didnt even look at the motherboard monitors to show voltage and temperatures, because I was just happy that it booted up. So, I was going to do some light overclocking on my X2-3800 and I installed a motherboard monitor and also the standard motherboard utility provided by Abit(the motherboard is a KN8 without SLI).
I thought all was fine, but before I started to overclock I looked at my voltages and they are crazy, varying as much as .4 volts. My 3.3V reads as low as 2.98, my 12 V can read near 11.75. I know are far as variance goes, the 12V isnt too much of a problem, but the 3.3V worries me. My system is rock solid with a 400 mhz overclock(I will try to get more later).
Also, what are the negative values in my monitor software? I think it has a -12V and a -6V, and these values are much worse. The -12 reads -5 or so... I never knew what these were in the first place so I didnt worry about them at all.
Should I be worried or is this simply a problem inherent with onboard and software monitors?
Thanks in advance for all help. FYI, I dont own a voltage meter(or whatever they are called) so I can measure the volts without the software.
Sponsored Links
I dont think its the silverstone, thats quite a rock solid PSU!
I think its the MB it only has 4 phase voltage regulators now days MBs from 955x and nforce 4 (32) chipsets and up have 8 phase voltage regulators.
Reply to wun911
thanks for the reply, it sounds like I dont have to worry about it, especially since my computer is stable.
Reply to BlackWyvern3
There are 659 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
