hi guys, my system spec is as follows
Athlon Xp 2600
MSi N-force2 mobo
1 gig kingston value ram DDR333
2x120 gig maxtor HD, ultra-133.
Sb audigy.
Galaxy 6800GT 256mb.
PSU=Antec 400W, 18A max on 12V rail.
AGP voltage at 1.6V
i bought a new speaker, a PCI usb 2.0 expansion card and a logitech G15 keyboard yesterday, and i hooked everything up fine except the pci card, it gives me alot of problems so i left it in and didn't use it. I was watching a movie on the computer and all of the sudden the monitor shut off. my computer appears to be frozen as well. so i pressed the restart button, and there is nothing that appears on the screen.
I put in my old 9600XT card and everything works fine now.
I suspect that its either the graphic card, or a power issue.
I tried unpluggin all the devices except the mobo and the graphic card, it still wont POST. All the fans spin, although the air inside the case seem alot cooler than before when i had the 6800GT in.
What do you guys suggest? Thank you for any input
Athlon Xp 2600
MSi N-force2 mobo
Sb audigy.
AGP voltage at 1.6V
