Im haveing some problems with a new PC im building for a friend.
My set up is as follows:
Tagan 500 wat PSU
P5WD2 Premium MB
1GB Kingston DDR2 Value RAM (2x 512 both in the yellow slots)
Maxtor Maxline II 250G HD
Intel Pentium 940 Dual core 3.2
Gigabyte 7900GT
Sony DVD ROM
Lian Li PC 60
I have pluged everything in one pice at at time (including the 24pin and an 8 pin power to the MB) everytihng powers up. The fans are on (CPU, case and GPU fans) the green LED on the MB is on and the CPU gets hotter as does the GPU but no POST beeps, cant even get into bios. I just have a blank screen on my LCD.
I have tried resetting the CMOS differnt vido cards that I know work etc etc etc,
I have heard of similar problems from other users:
http://www.techsupportforum.com/asus/99083-post-problems-p5wd2-premium-bios.html
They say that the BIOS in the MB is old and does not support dual core 950s (even although this chipset is a 955x). So I must update the BIOS... How the hell am I going to update bios unless I have a single core CPU?
If i must get another CPU I would probably get a 805....(just to OC for fun) but I'm not sure if the MB will even support an 805 without the updated BIOS. Will this MB support an 805 no worires?
Tagan 500 wat PSU
P5WD2 Premium MB
Gigabyte 7900GT
Sony DVD ROM
Lian Li PC 60
