help me choose the right case/psu
  • Power Supplies
  • Components
  • Product
Last response: in Components
May 18, 2006 11:02:55 AM
I need help !!! :(
I am planning on building my computer this days.I made sure it is on AMD,but
i'm not sure what is better from the list bellow:
-Antec performance TX1088AMG 480 W Power supply
-Termaltake VB1000SNS/Enermax Liberty ELT400AWT ATX 12V
-Termaltake VB1000SNS/Termaltake PurePower460W ATX 12V P/NW0068RUC
-Nexus Breese 500
I have no choice because i am outside US.The price is important and i prefer to save some money
This are my specs.
AMD Athlon 64 3200+ (venice)
DFI nForce 4 SLI Infinity(939)
Crucial PC3200 2x512MB Ballistix
eVGA geForce 6800 GS 256MB
WD Caviar SE 250GB
NEC ND 3550A
Benq 652A 52X
Please give me your opinions and comments.
More about : choose case psu
May 18, 2006 12:23:45 PM
Since I am not a fan of fancy side-panel window cases, I would probably go w/ the Antec since it has the TPII-480 and a 120mm included w/ a couple of front 80mm mounts and the side panel can be easily modded w/ 2 80mm's for extra cooling if needed.
But the Thermaltake soprano w/ the Enermax is no slouch if you want some style and a side panel window, the 2 120mm fans will be quiet and cool.
May 18, 2006 11:02:34 PM
I would lean toward at least a 500w psu, good for sli and overclocking
May 19, 2006 6:30:18 AM
Any of those will work just fine for your components... I'd go with the Antec, personally. Excellent PSU.
May 19, 2006 7:06:07 AM
I will second the Antec TruePower II 480 or 550 watt PSU...
Excellent quality at reasonable pricing.
May 19, 2006 8:37:20 AM
I would choose Antec because first of all, that PSU is great, the case looks nice and has a good airflorw .
May 20, 2006 6:43:15 AM
Thanks!
I will go w/Antec,the case has already 480w PSU.Can't find 550w ...
