I have ASrock 939Dual-SATA2 (M1695) MOtherboard, well I was setting it up and I did somethings that may have led me to Killing it...Ill explaing.
1) The power supply that came with the case was 24 pin, the board is 20, but it seemed that you could tear off 4 pins, so I did, I had to get some scissors to cut the plastic edges but after that it fit in the board, the remaing 4 pin piece I stuck in the 12V 4 pin connector in the board.
2) I put the MB pannel power switch on hot to ground, and not hot to hot
Once I had the power switch connected to the board I decided to fire it up and see if it would run then turn it off and continue hooking everything up, ( I had the CPU and Memory in FYI)
I flip the switch on the PS and hit the case power button, nothing happens, So I take out the extra 4 pin, try again and this time when I hit the PS switch in back the CPU and case fans move for a second! Now I hit the Case power button and things start up then about two seconds later the board starts smoking.
Of corse I instatly switch everything off, I flip the MB pannel power switch meaning. I flipped hot to hot, ground to ground (?) I never new which was which anyway but I repeated the process. THis time everything worked and turned on with no smoke...I was satisfied, I switch everything off again.
Now when I tried again with everything set-up nothing works at all, everything is entriely dead. I've backtracked through all the steps and absolutly nothing, What happened??? And is there anything I can do to Save my computer???
Thank you!
Thank you!
