I have a P4 3.0ghz processor that uses PC3200 RAM, and an old GeForce 4 4400 AGP video card. I was trying to install Windows a while back and I screwed up the installation.
All it does upon boot is hang at the part of the process right before the RAM counts down, and you can see that if you press DEL you'll be able to get into BIOS. However, if you press DEL, you can't get into BIOS.
I had a buddy look at the computer, and he told me that he set it all up and that the problem was with the video card, which admittedly had a bad fan. He told me that it worked fine with his other video card, but that nothing would appear on the monitor. Now, it appears that he likely didn't do anything, if at all with my computer problem (he had it for 2 months and kept forgetting about it). Long story short, he won't answer any of my emails and I don't have any other computer-savvy friends nearby.
So here's my question: Do you guys think that I should simply replace the motherboard (I don't even have a spare floppy drive to flash it or anything), or should I replace the video card? Which will solve the problem in the easiest manner? And if I should have to replace the motherboard, which type should I get (I don't know what sockets or what type of motherboard I currently have)?
