I have a 7600GT that's overclocked 50mhz, the temp I get while idle is around 60c and while under a load goes up to about 67c. However, if I return it to stock settings, I get the same temperatures. I've been using everst home edition to check my temps, but the only thing it gives me any reading for is the GPU. So my first question is, what other program can I use the would most likely be able to read all of my components, and my second question is, if infact my card is actually running that hot all the time, is there something wrong with it?
