First Build. I'm having problems getting much of anything to work on my new motherboard (pls. see specs below). After having trouble getting any more than an LED light to come on I emailed Antec who suggested disconnecting everything except PSU & Fan and then touching the front (soft?) on/off pins w/a flathead screwdriver. This worked -- fan operated for the first time. Then I connected the CPU & Heatsink and tried using the front panel Power connector (two-pin thing) -- did not work. Reversed the connector direction -- this did not work either. Left the CPU & HS connected and tried the flathead screwdriver method -- this time both the PSU fan & CPU fans came on.
What does this indicate? I don't know where to go next. I've got nothing else attached - not even memory.
I'd appreciate any advice. Thanks. mcaren
Antec Solution SLK1650B Black Steel ATX Mini Tower Computer Case 350W Power Supply
AMD Athlon 64 3000+ Venice 2000MHz HT Socket 939 Processor Model ADA3000BPBOX
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model VS1GBKIT400
SAMSUNG Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP
Western Digital Caviar WD800BB 80GB 7200 RPM IDE Ultra ATA100 Hard Drive
BIOSTAR GEFORCE 6100-M9 Socket 939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
SAMSUNG Combo Drive Black IDE Model SH-M522C/BEBN - OEM
