Tom's Hardware > Forum > Storage > Hard Disks > help..hard disk fan driving me nuts
Forum Storage : Hard Disks - help..hard disk fan driving me nuts
I have a Seagate 7200 rpm 60 GB drive(exact model # not known). I have a fan in front of it, and it just keeps getting noisier. There is also another drive on top of it. The case does have a fan built in..would this be sufficient to cool the Seagate? Its either that or pull my hair out.
Sponsored Links
A few options. Replace the fan(not exactly expensive). Remove the noise
maker..Fan in front will probably do the job, and Seagate drives usually run
a little cooler than most. You can throw a low-noise fan in there. Or, check
and make sure the offending fan isn't plugged up with dust, and dirt. I save
old toothbrushes for this purpose, and they are great for getting "into" fans.
Clean both sides of the fan blade, as well as the motor body, and inside
the fan casement. Compressed air can also work well for this, but isn't
free. GL :)
Actually, with 2 HDD's stacked, it's probably best to ensure adequate
circulation with a dedicated fan.
Reply to 1Tanker
Definitely replace the fan with a quiter one (Newegg.com) for hard drives do not need a fast fan for it doesn't generate much heat and idles at 3-5c higher than the ambient room temps with a fan in front of it.
Reply to chuckshissle
Wow that was a question that required serious thought.
You really had to post that on the forum???
What to do about my loud annoying fan? hmmmm.........thats a toughy, have you tried rebuilding the fan or wearing ear muffs so you cant hear it? Those would be my first suggestions. :roll:
Reply to MrsD
Quote :
Better yet send the dying fan to be recycled and buy a new one! :-D
Reply to linux_0
Quote :
Better Idea. :wink: Post the question to bug people, like MrsD, that have
a severely shortened fuse, and think nobody's worthy of their help.
Reply to 1Tanker
Quote :
:D Happy thoughts! Happy thoughts! :D
Reply to linux_0
Quote :
:D Happy thoughts! Happy thoughts! :DLOL :)
Reply to 1Tanker
There are 560 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
