Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Question about power for ATI x800gto
Forum Graphic & Displays : Graphics Cards - Question about power for ATI x800gto
Ok my friend is thinking about buying a vid card x800gto (agp), for his 2 year old computer, is it necassary for it to be attached to the extra 4 pin power on the card or it could run without it?
thanks in advance
Sponsored Links
that would be a YES it would require power.
http://images10.newegg.com/NeweggImage/productimage/14-102-608-02.jpg
Reply to TheMaster
He is right. :roll:
The agp X800GTO does require power form a standard 4-pin connector.
BTW I have a Sapphire AGP X800GTO. Doesn't overclock much but unlocked to 16 pixel pipes. :D
Reply to Scougs
what about a 6600 gt?
Reply to xxeddydxx
It would aswell,
does your friend not have enough power connectors?
Reply to TheMaster
he has a couple but they are not long enough
Reply to xxeddydxx
If he is buying it new (not used or refurbished) it should come with the 12v power adapter/splitter/ extension cable. He'd be good to go assuming his power supply has the juice needed.
Reply to pauldh
ohh ok thanks but the thing is his power supply is 300 watt, so if it doesnt work we have to get him a power supply :?
Reply to xxeddydxx
There are 642 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
