Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Don't much about computers, want to build one, need help.
Forum Homebuilt Systems : General Homebuilt - Don't much about computers, want to build one, need help.
I currently own a laptop which stays at home and a mac that I carry around to school and stuff. A lot of my friends are playing World of Warcraft and that game seems to run really slow on my laptop so I want to build a computer just for gaming purposes. My friend recommended this website so here I am. I don't know if this is the right section to ask for help, if it's not, I'm sorry and please direct me to the right section. Anyways, I'm willing to spend around $1,500 dollars for the best gaming system I can buy. I already have the Windows operating system so I don't need that. I just need the hardware. Would you guys please give me some good recommendations? Thanks in advance.
Charles
Sponsored Links
First timers should ALLWAYS have a more experienced techie around when building their first rig as there is a million situations where having him there would be helpfull.
If you need advise i can give you that
msg me on aim: MyTieForPeace
don't msg me if i'm on mobile
I am a certified computer technician with plenty of experience building custom rigs.
I have my A+ along with TCT TAT and MCSA certified.
Reply to WhatUsername
Smart friend, pawning this off on us to help you. Put together a list of parts from Newegg or something and post it here so we can make suggestions to help you get the best parts for your money. I would start you off a basic list of parts in your budget range, but I'm not sober enough to do that right now.
Reply to moparman390
Hey man i'm newbie here and also willing to buy a new rig at the end of my summer holidays...... hopfully i save enough bucks to buy the new rig! Anyways this is what i'm trying to get. They might not be the very latest hardware but its the best system i can get for my buget.
i also need to buy a monitor and keyboard and mouse which evetualy tightens my buget
then hook the new rig with my network so i don't realy need a printer
i also own a case and floopy disk
Cpu: AMD 64
Motherboard: an Asus Socket 939 (Cpus accepted by the mobo: Athlon 64 FX/Athlon 64 X2/Athlon 64/Sempron)and SLI graphic cards
RAM: 1 Gb
Hard Disk : A Western Digital Sata hard disk
Garphic Card : well i'm geting ATI Pci-express then change sli later
Power Supply : 500w power suply
those are the main basic things then u need to invest some good bucks on cooling systems escpecially cpu and graphic card
( remember that a well heated Cpu and Graphic Card will result into very low performance)
well hopfully it was a good help to begin with. Do some resaerch trought reviews and forums those will really help .
Good luck
BDW: i'm still doin' my resaerch for my components
Reply to juvealert
hey man so ur saying that
if i get an nvidia chipset mobo i need to get an nvidia graphic card ?
and the nVIDIA nForce4 SLI X16 chipset can i use a single pci-express card ?
thanks for ur information duds
Reply to juvealert
thanks man
i'm still doin' my research trough forums etc.
i will post my rig when i decide some time later this summer as i prevously said.
i know some techniamal experts which i trust
any way thanks
Reply to juvealert
Quote :
you can still run a single ATI video card in an nvidia chipset board. even the sli one. but if you want to run 2 ati cards you need a crossfire board and a crossfire video card.
I think thats wrong. I thought that i read somewhere that you can run crossfire as long as the mobo supports 2 8x pci-e (think of the new 975 chipset from intel)
edit this is a list me and another guy made on another forum. https://secure.newegg.com/NewVersio [...] tle=Morbid it comes to roughly 1100 $. If you up the proc to an opty 165/170 and the gfx to a 7900gtx or an x1900xt you should be exactly at your 1500$ price limit. Guess thats pretty much the best bang/buck setup.
or if you can wait: conroe will be out soon (23ed June?) and AM2 should have its bugs worked out soon
Reply to nigelf
Indeed you can run Crossfire on an nVidia SLI board, and the most amusing thing of all is, it runs faster than a native X-Fire board! This of course due to the fact that nVidia chipsets are 359237 years ahead of ATI ones.
Reply to shadowduck
if you plan to stick with mmorpg's such as wow, unless things start changing radically youll always be able to play games like that about one or two technology generations back, not a bad thing if you ask me, its just that FPS is usually the game type that pushes cpu's, and gpu's to their limiits. So like someone said in there post above, for now, with WoW youd probrobly be fine running like an athlon xp 3400, a 7600gt a gig of ram on a 939 motherboard. and have plenty of money left over in your pocket for cooler accesories (im guesing you dont have these to cary over as if I understood correctly you dont have an existing pc) go for a nice headset if you plan to voice chat, a nice keyboard and mouse, maybe a nice sound card if music is your thing, a 5.1 speaker system, have some fun with it and customize it.
Reply to Suffix
Quote :
Well if you want to go with a possible SLI rig, here is a starting idea for you: SLI pc. It is kinda overkill for what you intend to play but should you decide to play something that needs the more powerful graphics this will handle it better than a rig with less graphics power. I have a friend that plays WoW and his pc is similar to the one in my sig except for the overclock, and he is still running a 6600 nvidia and an older ide 80gb WD and he says his plays just fine.
Fukc SLI; get an X2 3800+ and an X1900XT instead. The rest of those components look okay.
Quote :
You actually can do X-Fire on an SLI board; it's just difficult.
Reply to angry_ducky
Hey if you want your computer put together for you check out built4ucomputing.com. they will order, build and ship your computer for you based on your parts list or they will suggest components based on what it will be used for.
Reply to braves4life
There are 1228 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
