Archived from groups: comp.dcom.voice-over-ip (More info?)
I tried to use a Panasonic 5.8 GHz cordless phone with Vonage box, and
then with the Sipura 2100. It shows the same problem with both, that
when I speak loudly into the handset, the person on the other end can
hardly hear anything. However I can hear the other person fine.
It is not a problem of the VOIP ATA itself, because a corded phone
works fine. It is not a problem of the Panasonic cordless phone
itself, because with a POTS line it works fine. Rather it is a problem
of the VOIP ATA / Panasonic cordless combination, but what is really
strange is that the problem existed with the Vonage Motorola adapter,
and still exists with the Sipura 2100.
Vonage couldn't figure out what was wrong. I read on their website
some mention that people were having trouble with cordless phone using
Vonage ATA, but no mention of why.
So... why would this happen, and what can be done to fix it? Besides
getting a different cordless phone?
Do you have a wireless router? How far from the TA is the cordless base?
I had a similar problem without the VOIP. In my case, everytime I used
the cordless phone, my wireless network would die. I got a different
brand cordless phone and the problem disapeared.
You need to keep in mind that wireless routers and cordless phones use
the same frequency.
Yaser Doleh wrote:
[snip]
> used the cordless phone, my wireless network would die. I got a
> different brand cordless phone and the problem disapeared.
> use the same frequency.
Not here (UK) they don't. Routers use the same 2.4 GHz band as other
devices such as wireless CCTV cameras but the digital cordless phones in
use here use frequencies somewhere in the 860 MHz band I believe. I've not
come across a phone (or a router, or anything else for that matter) using
5.8 GHz here.
Ivor Jones wrote:
> Yaser Doleh wrote:
> [snip]
> 5.8 GHz here.
> Ivor
The OP was using "Vonage". But you make a good point about frequency
usage in different countries.
On Mon, 21 Feb 2005 17:01:12 -0500, Rick Merrill
The wireless router, cordless base and ATA are next to each other. I
don't see why it should matter, since wifi is 2.4 GHz (?). Anyway, I
can hear what the other person is saying, they can't hear my voice
clearly.
It's a Panasonic cordless if that makes any difference.
It is possible for their frequency generators to interfere with one
another - remote, but possible. Try placing them all as far apart as
possible and test that. Also, your wireless router and Cordless base may
be using the same frequencies (in the US) - check that!
Sounds more like the AGC on the panasonic has a wider range than the VOIP
ATA handle resulting perhaps in an overflow / underflow condition in the bit
conversion. Does it make any difference if you adjust the volume on the set
(not sure if volume adjusts both incoming and outgoing speech)?
<omni@zmaxdap.com.spam> wrote in message
news:u0kk119skg0b57mtj50ob84ck4dln358qv@4ax.com...
Vonage is available in UK. Op may in fact be in UK.
T. Sean Weintz - T. Sean Weintz - T. Sean Weintz - T. Sean Weintz
May be copied freely without the express permission of T. Sean Weintz.
T. Sean Weintz could care less. T. Sean Weintz does reserve all rights.
On Tue, 22 Feb 2005 10:46:47 -0500, "Budwich" <budwich@noshrogers.com>
This sounds the most promising explanation, because the phone works
fine with POTS line, and a corded phone works fine with the ATA.
> Solution, get a different phone.
I've found that Uniden cordless phones work very well with the Vonage
ATAs. Only problem is that thhe 5.8GHz FHSS models all come with
answering machines which of course won't get any use under Vonage (and
the non-answering machine units are all analog, which I would never
use). They do have a DSS 2.4GHz basic cordless phone though, model
DCT646, that plays well with the wifi network in my house, so you may
want to try it.
E-mail fudged to thwart spammers.
Transpose the c's and a's in my e-mail address to reply.
> For the second time: the OP stated he was using a 5.8GHz cordless
> phone. 802.11b/g/n is 2.4 GHz.
I have never heard of any cordless phone using 5.8 GHz. Can you give me a
website of anyone selling these..? All digital cordless phones in the UK
at least use 2.4 GHz.
Even phones labeled prominently as 5.8 ghz may in fact be 2.4 ghz in at
least one direction - labels on the phone and packaging mean nothing. How
they can get away with this, I don't know.
"Isaiah Beard" <sacredpoet@sacredpoet.com> wrote in message
news:112ccgrqrjlq96@corp.supernews.com...
> For the second time: the OP stated he was using a 5.8GHz cordless phone.
Oh, in case you think I'm nuts, here's proof:
This phone is claimed to use 5.8 ghz right on VTech's website:
http://tinyurl.com/blkxk
However, look up the part 15 approval on the FCC's website, and it turns out
it's on 2.4 ghz for one direction, and 5.8 ghz for the other.
http://tinyurl.com/bwz38
"Bob" <BobsJunkMail@bellsouth.net> wrote in message
news:kwPie.6504$fE3.3227@bignews1.bellsouth.net...
news:_EPie.6565$fE3.1309@bignews1.bellsouth.net...
> http://tinyurl.com/blkxk >
> out
> http://tinyurl.com/bwz38 >
>> > phone.
I'm not sure who that reply is to, but it doesn't say 2.4 ghz on the box, or
in the ad on their page.
"R-Guy" <ron-20050103@mcleodnet.com> wrote in message
news:57Sie.1409838$8l.278459@pd7tw1no...
> From the manual ...
> TRANSMIT FREQUENCY
> Base: 5744.736 - 5825.952 MHz
> Handset: 2401.056 - 2482.272 MHz
> RECEIVE FREQUENCY
> Base: 2401.056 - 2482.272 MHz
> Handset: 5744.736 - 5825.952 MHz
> 802.11b Channel 1 = 2412MHz
> 802.11b Channel 11 = 2462MHz
> > http://tinyurl.com/blkxk > >
> > out
> > http://tinyurl.com/bwz38 > >
How
> >> > phone.
>>From the manual ...
>>TRANSMIT FREQUENCY
>>RECEIVE FREQUENCY
>>>out
>>>>>phone.
Thanks Bob and r-guy for backing up my suggestion, but I would guess
that the OP isn't listening!-)
