Archived from groups: comp.periphs.printers (More info?)
Hi!
I have an Epson 890 Photo which i am having problems with. Each time i
print an A4 sheet of pictures (contact sheet) the printer dumps a line
of black ink across the page (roughly 2cm into the print) which then
gets dragged all down the page and ruins the rest of the pictures.
The ink dunped appears not to be a printed line because it is dragged
or smudged so it appears to be blobs of ink.
If i print a letter or anything else all is well. This is naturally
very frustrating and have grown tired of banging my head on the wall.
Thanks for any suggestions.
Engelkott
Engelkott wrote:
> Hi!
> Engelkott
I'm not an Epson expert. But I don't I need be in this case. . . .
Something as simple as a slightly curled sheet - and photo papers
can be notoriously curly - can do this by inadvertently making contact
with the print head as it passes overhead. Remember the gap between
the print head and the paper is very SMALL. The underneaths of print
heads always carry patches of old ink. Try to straighten the paper
as much as possible so that it is almost perfectly flat, so that
no part of it will be "high enough" to strike the print head. Or if
necessary, curve it slightly by hand to the shape of the paper path.
I have had this happen myself with various papers. Remember, you had
stated that it doesn't do this with normal text printing. Good luck!
-Taliesyn
__________________________________________________________
The Taliesyn Website: http://www.colba.net/~andresk
>-Taliesyn
Thanks for the reply! What you have said makes perfect sense now you
have said it!
The corners of the paper do curl up slightly so i
will try to straighten them. The paper in question was Ilford Satin
paper.
One question i have though is why does it take 2cm to deposit the ink
across the page and not straight away?
Cheers!
Engelkott
>>-Taliesyn
> have said it!
> paper.
Just the way it feeds, I guess. Yes, those corners are the most
important parts. I have actually had this happen on slightly
curled at the edges coated paper on my Canons (iP5000 and i860).
After a few black stained ones I got the message that the printers
didn't like their pages curled. :-(
> Cheers!
> Engelkott
Cheers to you too, and may all your pages remain flat!
-Taliesyn
Just another thought, could it be paper thickness too? I have never
adjusted the lever on the side for paper thickness so maybe if i move
that it would help?
Cheers!
>> Cheers!
>> Engelkott
>-Taliesyn
I have been considering getting a Canon to go with my Canon cameras
and scanner. I like the 900 series, is there a printer you would
reccomend i take a look at?
Cheers again!
Engelkott
Taliesyn is on target with the paper curl issue. Canon support has an faq
that deals with this problem and has the fix that Taliesyn suggests. I have
a canon i960 and had a similar problem. I found that when I left photo
glossy paper in the printer feed area over a period of time it took a slight
curve and caused the problem. I now store my paper flat in a drawer and
only load it onto the feed area when I am printing. I remove what is left
after a print session and put it back in the flat storage area in my desk.
On the Canon there is a software adjustment for thicker paper and it works
well. It is a nuisance as there is a pop-up box that appears with each
print you do to verify the thicker paper function. On the Epson I had there
was simply a lever for thickness adjustment. I would first clean the print
head and store paper flat if you don't already do that.
There is a technique for cleaning under the print head of the Epson printers
that is included in Art Entlich's instructions for cleaning Epson print
heads. Send him an email at artistic@telus.net and request his
information on Epson print head cleaning. I had an Epson Stylus 900 that
had occasional head blockages and his instructions were the best for
restoring it to like new function.
For some great information on printers, canon printers, aftermarket inks,
etc, go on to Neil Slades site. The link is
http://www.neilslade.com/papers/inkjetstuff.html . At his suggestion I
bought the I960 and really like it. I also took his advice on third party
inks and have been very pleased. Taliesyn also uses third party inks very
successfully.
"Engelkott" <nomail@hotmail.com> wrote in message
news:kgjr31tdrv79abc14elvin5hjsn83h5csh@4ax.com...
> that it would help?
> Cheers!
That's absolutely good advice of not storing photo paper in the printer
as it tends to curl even more. I too store it flat elsewhere and insert
it only at the moment of printing.... or right after the printer tells
me via a pop-up that I haven't inserted a paper in the machine ;-).
Funny, I've never seen this paper thickness adjustment option for the
Canon. Where and when does it appear? I was just looking for it for
my iP5000 and i860 and failed to find it.
-Taliesyn
If you keep it flat under a book or similar, the weight will stop it
curling (flower press principle). The flat card packs paper
comes in are ok until you remove some sheets, the rest then
curls.
On Sun, 20 Mar 2005 15:18:47 -0500, Taliesyn <taliesyn4@netscape.net>
>-Taliesyn
Thanks for the storage tip.
The paper thickness adjuster is a little lever under the cover where
the cartridges live. It moves the roller up and down slightly but i am
not sure if it moves the print head too.
Engelkott
>>>Cheers!
>>>Engelkott
>>-Taliesyn
I don't like recommending because printers sometimes break down suddenly
and I don't want to look the bad guy. But I use an i860 and the recent
iP5000. I was supposed to get the lesser iP4000 but my store didn't have
any. The difference was $50 (CDN), I said go for it. It uses the same
cartridge alignment as the i860 and prints gorgeous photos, and works
flawlessly. The main technical difference is that the iP5000 prints with
smaller ink droplets than the iP4000, and a resolution of 9600 vs 4800.
I find prints with the iP5000 don't show the very faint head pass lines
(visible on SOME photos) that I can spot on my i860 when the finished
photo is turned 90 degrees. I believe I read somewhere that it was a
fault of the feed mechanism. Can't say for sure.
-Taliesyn
Either the discontinued i960 or the IP4000.
>>>Cheers!
>>>Engelkott
>>-Taliesyn
>Cheers again!
>Engelkott
>>-Taliesyn
You mean on your Epson. I don't think the newer Canons have such
a lever. I think my earlier i850 had a lever and then it magically
disappeared on the i860. And I've never bothered with thickness
ever again - envelopes, thin paper, thick paper - all treated the
same.
-Taliesyn
On Sun, 20 Mar 2005 19:47:19 GMT, "Burt" <sfbjgNOSPAM@pacbell.net>
>successfully.
Thanks for all your advice. It is appreciated!
Engelkott
Taliesyn - check out your printer driver software. For the i960 you click
the maintenance tab, custom settings, and activate "prevent paper abrasion."
I guess that this increases the paper feed gap slightly. It did work, but
as I mentioned in my previous post to this thread, there is a dialogue box
that pops up for each print. It was much easier to store the paper
properly! At the same time I also ran into a problem with 4x6 borderless
printing of banding on the last 3/8 inch of the trailing edge of the
picture. Same problem of paper curl.
"Taliesyn" <taliesyn4@netscape.net> wrote in message
news:3a644tF688o1uU1@individual.net...
>> faq that deals with this problem and has the fix that Taliesyn suggests.
>> I have a canon i960 and had a similar problem. I found that when I left
>> photo glossy paper in the printer feed area over a period of time it took
>> a slight curve and caused the problem. I now store my paper flat in a
>> drawer and only load it onto the feed area when I am printing. I remove
>> what is left after a print session and put it back in the flat storage
>> area in my desk. On the Canon there is a software adjustment for thicker
>> paper and it works well. It is a nuisance as there is a pop-up box that
>> appears with each print you do to verify the thicker paper function.
> -Taliesyn
Thanks. I have seen that "Prevent Paper Abrasion" check box, but
couldn't figure out what that meant. Perhaps had they called it
"Increase paper to printhead gap" it might have meant something.
About the banding, I found this at a website... "The banding problem (on
the printed side) is reduced with the Post-It note (Have a look at the
US Canon service site)".
I should check this out at the US Canon site too as I have seen banding
on my i860 prints in the last inch area of some photographs. I don't
know specifically which printers are involved. So far I haven't
noticed any problems on my iP5000.
-Taliesyn
On Sun, 20 Mar 2005 20:27:40 +0100, Engelkott <nomail@hotmail.com>
>Cheers again!
That depends - do you want to keep your prints for any length of time?
Hecate - The Real One
Hecate@newsguy.com
Fashion: Buying things you don't need, with money
you don't have, to impress people you don't like...
The IP Pixma software is the same for this choice.
>>-Taliesyn
>same.
>-Taliesyn
I have never bothered to adjust the lever before but with the problem
i have been having it might be a solution as the paper is 250gsm. The
paper i print letters on is Epson 80gsm.
Engelkott
>>Cheers again!
No, not for long. If i print anything to frame i use a pro lab s i
still prefer the finish you get from a lab and besides that the costs
are not too bad.
I will mainly be using it to print things for other people or to make
walled portfolio snaps. The credit card holder size pics but they are
rotated every once in a while.
Engelkott
>>same.
>>-Taliesyn
> Engelkott
250gsm? Is that the same as 250g/m2? I'm more used to the lbs thingy.
My Costco Kirkland photo paper is labeled 68lb 260 g/m2 / 10 mil. This
is very nice thick stuff, with a hard, almost glass-like finish. Okay,
I exaggerate a little. But it's wonderful paper and it works just fine
in my Canons with no paper thickness adjustments necessary. There have
never been any stray ink marks on them. They come 8.5 x 11, but I just
"Edward Scissorhand" them down to 4 x 6 size for photos. I use a mela-
mine cutting surface, an exacto knife (from the dollar store), a metal
ruler, and the comparative method to cut them to size. Comparative met-
hod means I simply use a scrap 4 x 6 (or longer the better) photo as a
measuring guide. Usually I just cut them to the 4 inch width, leaving
the length 8.5 inches, or whatever. Then after the photo is printed, I
just trim off the excess from the length. Very simple. As this paper is
instant dry, I don't have to worry about handling it right away.
-Taliesyn
Taliesyn - If you print any kind of volume of 4x6's do yourself the favor of
buying a paper cutter with an adjustable guide bar. Much easier and faster
and you can cut a box of Kirkland paper into 375 4x6's in around half an
hour. one of the reasons I went from my Epson Stylus 900 to the canon i960
was the borderless 4x6 print capability that saved me endless hours of
trimming!
news:3a72tgF68th95U1@individual.net...
>>>same.
>>>-Taliesyn
>> Engelkott
> -Taliesyn
If you can scan the defect at 300 dpi (not the full page, just the
defect and about 1" to either side) and jpeg it at high quality, and
send me it as an attachment privately, I will try to diagnose it and let
you know what is the likely cause and possible solution.
Use the email address I have posted this from.
Art
Engelkott wrote:
> Hi!
> Engelkott
Chances are you have a problem with both dried ink and dust or even a
hair under the head, as Taliesyn suggests, but I wanted to see the exact
problem before making a diagnosis, because some descriptions I get are
not clear enough to define the problem.
Try raising the head with the paper thickness lever and see if the
problem still occurs, or is lessened. The fact that the line is as
defined as you suggest may mean there is something else up as well.
If you send me a private email requesting the Epson Cleaning Manual, I
will send you a copy. It explains a safe procedure to clean under the
heads. There is no cost for it, and no spam.
I still suggest you send me a scan of the defect so I have more
information to go on.
Art
>>-Taliesyn
> have said it!
> paper.
> Cheers!
> Engelkott
The paper you speak of (Kirkland /Costco), I'm guessing is made by
Konica. They have a paper was called Konica QC which was actually
coated with a ceramic coating and it does look like glass. They now
state it is resin coated, so maybe its been changed. I've been looking
for a cheaper source for it, as I really like it with my Epsons. It
apparently is microporous technology, meaning it is not as permanent
with dye inks as a swellable polymer might be, but it usually is water
proof once it dries, and the surface, when one is after that mirror
gloss, is just beautiful. I'm going to have to track this down... I
hope they have it in Western Canada. Office Depot brand paper in the US
seems to be Konica Premium Glossy, but not in Canada.
The specs seem correct from what you've stated:
See:
http://bt.konicaminolta.ca/product [...] lossy.html
Art
>>> same.
>>> -Taliesyn
>> Engelkott
> -Taliesyn
> trimming!
Yeah, a cutter's good. The main reason I don't use one is that I don't
have large runs of photos where I need to cut a lot of them. My efforts
are more in the range of 1-4 at a time. And cutting a full sheet into
3 photos takes me under a minute. Also, I'd like to preserve the full
size sheets in case I do 5 x 7s or larger. I can see the point if I
was to go on vacation and return with 300 shots. Yeah, I'd use a cutter.
-Taliesyn (yes, I know the website below shows a Christmas creation,
but I'm too busy at the moment to update)
> Konica.
That is in the past. Made in Switzerland, word has it that it is Ilford
Gallerie Glossy. I would suggest you get a package $20 for 120 8.5x11
sheets. Then go get a package of Ilford Gallerie Glossy at
www.inksupply.com . Compare and let us know what you think.
> They have a paper was called Konica QC which was actually coated with
> a ceramic coating and it does look like glass. They now state it is
> resin coated, so maybe its been changed. I've been looking for a
> US seems to be Konica Premium Glossy, but not in Canada.
> See:
> Art
>>>> same.
>>>> -Taliesyn
>>> Engelkott
>> -Taliesyn
Arthur -- the Costco store in Richmond has it ($24.00 for 120 8.5X11
sheets), don't know about other Vancouver Costco stores.
rtm
"Arthur Entlich" <artistic@telus.net> wrote in message
news:q9x%d.53792$ZO2.37290@edtnps84...
> The paper you speak of (Kirkland /Costco), I'm guessing is made by Konica.
> They have a paper was called Konica QC which was actually coated with a
> ceramic coating and it does look like glass. They now state it is resin
> coated, so maybe its been changed. I've been looking for a cheaper source
> for it, as I really like it with my Epsons. It apparently is microporous
> technology, meaning it is not as permanent with dye inks as a swellable
> polymer might be, but it usually is water proof once it dries, and the
> surface, when one is after that mirror gloss, is just beautiful. I'm
> going to have to track this down... I hope they have it in Western Canada.
> Office Depot brand paper in the US seems to be Konica Premium Glossy, but
> not in Canada.
> See:
> Art
>>>> same.
>>>> -Taliesyn
>>> Engelkott
>> -Taliesyn
Los Angeles at $19.95
>rtm
>>not in Canada.
>>See:
>>http://bt.konicaminolta.ca/products/consumer/paper/inkjet/glossy.html
>>Art
>>>>>same.
>>>>>-Taliesyn
>>>>Engelkott
>>>-Taliesyn
On Mon, 21 Mar 2005 04:37:06 +0100, Engelkott <nomail@hotmail.com>
As long as you're not charging - otherwise you're going to have some
*very* unhappy customers
Hecate@newsguy.com
On Mon, 21 Mar 2005 00:03:56 -0500, Taliesyn <taliesyn4@netscape.net>
>>>same.
>>>-Taliesyn
>> Engelkott
gsm = grams per square metre. I.e modern measurements, not Imperial.
Hecate@newsguy.com
In other words, about the same price, considering the current exchange rate
between the Canadian dollar and the US dollar.... :-)
It sounds like it might be worth a try - I've been looking for something
that gives a print that looks reasonably close to what I see on the
monitor.
Al Preston
One heck of a lot of work for making one copy of a home-burned CD.
Art
Hmm...
I was just on the Ilford site and I can't find any of their papers that
quite matches the Kirkland. May be a different product being made by
Ilford's mills, but strangely the stats are nearly identical to the
Konica. Maybe Konica is also made in Switzerland now (used to be made
in Japan)?
Konica's paper is listed as 260g/m2 10.4 mil super high gloss
They have another high gloss professional product called Konica QP which
is 305g/m2, 11.8 mil, but teh one I used last was 10 mil.
Ilford Gloss Smooth is 280g/m2 10.8 mil 22-28% gloss at 20 degrees
Ilford Classic Gloss is 240g/m2 9 mil 50-80% gloss at 20 degrees
Ilford Smoth High Gloss is 235 g/m2, 7 mil 40% gloss at 20 degrees
I'll take a look at the Kirkland, but I'm really after a nicely
discounted version of the Konica QP (not QC, that was an error).
Branded as Konica, it's to costly.
Art
>> Konica.
>> See:
>> Art
>>>>> same.
>>>>> -Taliesyn
>>>> Engelkott
>>> -Taliesyn
Thanks for the heads up.
I'm not a member, but I have some friends who are. I live on Vancouver
Island, and can see if they are carrying it.
Art
> rtm
>>not in Canada.
>>See:
>>Art
That would be just about correct since the Canadian dollar is at about
..83 cents to the US $ now.
Art
>> rtm
No, the stuff i print for people is if they do some modelling for me
then i give them some prints in return plus the files on disc for them
to get reprinted later.
It is not my fault if they fade!
Engelkott
>>>same.
>>>-Taliesyn
>> Engelkott
I am not sure. On the Epson paper they quote it as 255 g/m2 but the
Fuji and Ilford paper has it as 270 gsm. I would guess it is one and
the same.
Engelkott
On Mon, 21 Mar 2005 05:36:59 GMT, "Burt" <sfbjgNOSPAM@pacbell.net>
>trimming!
I thought the Epson 900 had borderles prints? My 890 and my friends
895 has this function.But then maybe the model numbers do not run
concurrently?
Engelkott
On Mon, 21 Mar 2005 06:59:56 GMT, Arthur Entlich <artistic@telus.net>
>Art
Thanks for the offer but i have thrown the page away now. If the
printer should do it again i fill take you up on your offer. I should
be doing some printing tonight or tomorrow.
Thanks again!
Engelkott
All part of my usual "twisted logic", Art. If you're going to buy a high
quality printer and lots of affordable ink, then you might as well do
something with it instead of whine (not you, Art) and debate whether
Canon photos fade in dark drawers in six months. I've chosen the more
difficult route. I now have 7 "CD & Booklet" projects going back 5
years. They've been printed on Epson, Lexmark, and now, Canon printers.
(my astrological advisor doesn't see any HP printers in my lifeline).
And in all cases, I just checked by creations, they show absolutely no
evidence of fading.
And if you entertained any thought at all that I may actually be selling
my projects... banish it. It takes a full day of printing at the highest
resolution and then assembling to even make one copy. What would I
charge if it were legal, $200?? Who'd buy it? Anyone crazy enough to
still want one would get a polite reply telling them to use their own
initiative, resources, and most importantly, their own favorite songs
(not mine). Posting my creations from time to time merely showcases what
can be done with a little patience, talent... did I mention patience?
And hopefully gives people ideas for similar projects of their own.
Art, you are actually the first person to have even commented on the
Christmas project since it was posted back in early December 2004. It
seems everyone who has stopped by my website, accidentally or not, has
read the "small print", in two places I believe, and heeded the message
that the CD & booklet is not for sale. I thank those people for under-
standing.
-Taliesyn (hmmm, now I have TWO Canon printers... what can I create...?)
> Art
Art - Someone mentioned in a post that the Kirkland paper was Ilford Pearl.
The Ilford site shows Pearl as a slightly heavier weight paper. Perhaps
they use the same coating on a slightly lighter weight paper for the
discount store sales? Regardless of source, I would suggest you buy a box
and try it. I must say, however, that I like it better with my Canon i960
than my old Epson Stylus 900 (which I revived with the help of your
excellent monograph).
news:mnR%d.63887$KI2.19876@clgrps12...
> Hmm...
> Konica. Maybe Konica is also made in Switzerland now (used to be made in
> Japan)?
> I'll take a look at the Kirkland, but I'm really after a nicely discounted
> version of the Konica QP (not QC, that was an error). Branded as Konica,
> it's to costly.
> Art
>>> Konica.
>>> source for it, as I really like it with my Epsons. It apparently is
>>> microporous technology, meaning it is not as permanent with dye inks as
>>> a swellable polymer might be, but it usually is water proof once it
>>> dries, and the surface, when one is after that mirror gloss, is just
>>> beautiful. I'm going to have to track this down... I hope they have it
>>> in Western Canada. Office Depot brand paper in the US seems to be
>>> See:
>>> Art
>>>>>> same.
>>>>>> -Taliesyn
>>>>> Engelkott
>>>> -Taliesyn
This was the Epson STYLUS 900. Perhaps the Epson Photo 900 did borderless
prints, but the Stylus 900 did not.
news:qntv319iglhmegfr1j9ce1gidtko10pi0s@4ax.com...
>>of
>>faster
>>i960
>>trimming!
> concurrently?
> Engelkott
I stand by my original statement (below). It didn't imply you were
selling or making additional copies, and yes, I did read the "fine
print" on several pages that indicated you do not sell them.
Art
> evidence of fading.
> standing.
>> Art
I understood the Kirkland paper to be high gloss. I rarely use high
gloss, but I happened to really like the Konica results with Epson inks,
so for my portfolio sheets I didn't mind using it.
Next time I'm in Costco, I'll give it a good look.
Art
>>Hmm...
>>Japan)?
>>it's to costly.
>>Art
>>>>Konica.
>>>>See:
>>>>Art
>>>>>>>same.
>>>>>>>-Taliesyn
>>>>>>Engelkott
>>>>>-Taliesyn
It is high gloss with a very smooth surface (not totally smooth, but more
smooth than the Epson glossy photo paper that has a bit of an "orange peel"
irregularity.)
news:ssd1e.109684$fc4.30899@edtnps89...
>I understood the Kirkland paper to be high gloss. I rarely use high gloss,
>but I happened to really like the Konica results with Epson inks, so for my
> Art
>> Pearl. The Ilford site shows Pearl as a slightly heavier weight paper.
>> Perhaps they use the same coating on a slightly lighter weight paper for
>> the discount store sales? Regardless of source, I would suggest you buy
>> a box and try it. I must say, however, that I like it better with my
>> Canon i960 than my old Epson Stylus 900 (which I revived with the help of
>> your excellent monograph).
>>>Hmm...
>>>Japan)?
>>>discounted version of the Konica QP (not QC, that was an error). Branded
>>>Art
>>>>>Konica.
>>>>>See:
>>>>>Art
>>>>>>>>same.
>>>>>>>>-Taliesyn
>>>>>>>Engelkott
>>>>>>met-
>>>>>>is
>>>>>>-Taliesyn
On Sat, 26 Mar 2005 13:57:03 GMT, Arthur Entlich <artistic@telus.net>
wrote:
>I think Epson is being too conservative regarding the thickness of the
>paper, personally.
>I use the thickness lever all the time for thicker stock and although I
>can't swear to it without more research, I believe Epson indicated in
>one or more instructions that one could raise the heads with the
>envelope lever should I be using thicker papers.
>Art
I agree with what you said, it is just when a tech support guy says
something like he did it makes you stop and canvas opinion before
ruining a printer.
What would the consensus of opinion be on having renewable print
heads? Do the printers which have that (do HP?) have any advantage
over non-changeable head printers?
Engelkott
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
