Since upgrading to the 6.5 drivers I have been seeing strange graphical glitches on games. For instance on Condemned the shadows seem to spike (see screenshot). I also get a similar problem on BF2 (Screen 1, Screen 2).
I've tried rolling back to 6.4 but that didn't work. Also, I tried plugging the monitor into the x1900xt to see if it was a fault with the master card, but it still has the same problem. The problem also occurs when crossfire is enabled.
I've only had those problems in the begining, After startup while things are loding the screen will refresh a couple times, or there will be lines. The only other time i get them is when i turn crossfire on or off
have you tried uninstalling all drivers and doing a clean, fresh install? Also try disabling all non-essential apps in the background. You may have something corrupted that is installed incorrectly. Check your mobo's bios settings too to ensure that it is configured right for xfire.
a fresh windows install could also be the issue... how long has it been since you reinstalled windows?
all just suggestions mind you, I do not have xfire so these are just steps that could be used for many problems.
