Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Printers > I960 color problem
I960 color problem
Forum Computer Peripherals : Printers I960 color problem
Archived from groups: comp.periphs.printers (More info?)
I have noticed my I 960 is not printing in color correctly. I did a head
cleaning, when I do this does it not run any paper through the printer? Mine
didn't. I first did a nozzle check and the 6M cartridge did not show
anything. I did some cleaning and then a deep cleaning a couple of times and
it did start to show color on the page then. The colors at the top of the
page when it prints the bars is very light though, it might supposed to be,
not sure. I wonder if I could take the print head out and soak it in some
hot water and a 20% solution of ammonia, wonder if that would hurt anything/
Thanks in advance
Reply to jake
Was the printer ever working properly?
Did you change your printing protocols?
If the colors are excessively pink this may be a software issue (color
management being applied twice) particularly if the pink coloration shows up
in the print preview window.
Reply to Anonymous
> Thanks in advance
I had a similar problem, it came about because I did not change the ink
cartridge soon enough, and the corresponding part of the printhead dried
out -- at any rate that's my diagnosis. I don't know why magenta is so
fussy, though.
Taking a hint from an Epson owner who used Windex, I squirted a little
bit of Windex into the magenta cartridge, did a deep clean, and ran the
test print - showed marked improvement. SO did it again, and did it for
all six cartridges while I was at it. Much, much better.
But lately I've noticed faint streaking on the prints, and that means
another round of Windex cleaning. It may be that some dried/drying ink
from the docking station sponge is clogging the print nozzles, so I
would like to know how to clean or replace that sponge.
HTH&GL
Reply to Anonymous
- 0 +
First thing to do is insert another Magenta cartridge and see if the problem
might be the cartridge. Read Neil Slade's informative site on clearing
clogged jets. The link is
http://www.neilslade.com/papers/inkjetstuff.html . Very good information on
dealing with banding, jets not printing properly, etc. Since it is not
printing the nozzle check correctly it would not be color profiles. It is
normal to not use paper when doing the head cleaning, but you do not want to
do several deep cleanings. Generally, as Neil Slade writes, the way to
prevent these problems is to print full color photos often. He suggests one
a day at least. Nozzles clog when you don't use the printer. The test
print for the nozzle check is very light. You don't want to see any breaks
or unprinted bands in any of the color rectangles. Another test is to do a
six color "purge print" page with setting at plain paper. I think Neil has
one of these on his site that you can download. If not, you can get it on
the MIS ink web site. You can see the actual colors of the inks and see if
the printing is continuous or has bands of unprinted areas.
"Jake" <jfoster1@nospamcableone.net> wrote in message
news:113uopbhb2hmh42@corp.supernews.com...
> Mine
> and
> be,
> anything/
> Thanks in advance
Reply to BURT
Are you guys using OEM Canon Brand INK? If not what brand and source
are the ink you are using?
>> printer? Mine
>> times and
>> the
>> to be,
>> some
>> anything/
>> Thanks in advance
> ink cartridge soon enough, and the corresponding part of the printhead
> dried out -- at any rate that's my diagnosis. I don't know why
> magenta is so fussy, though.
> the test print - showed marked improvement. SO did it again, and did
> it for all six cartridges while I was at it. Much, much better.
> HTH&GL
Reply to Anonymous
- 0 +
Thanks for all the advice guys, I followed the link and I am going to try
that compressed air thing. Thanks again for all the help.
Mine
and
be,
anything/
> Thanks in advance
Reply to jake
On Mon, 21 Mar 2005 23:04:48 -0600, "Jake" <jfoster1@nospamcableone.net> wrote:
>Mine
>and
>be,
>anything/
>> Thanks in advance
I use Epson paper (cheap) and was getting a pink tinge. I changed the paper type
in print setup to the highest quality Canon paper. The pink went away.
John H
"All decisions are the result of binary thinking."
Reply to Anonymous
This brings up a point that many people underrate: the interaction
between ink and paper. I trust the following is both correct and clear.
Ink will change colour when exposed to acidic (low pH) or basic (high
pH) environments. Papers are more or less acidic, and many papers are
both: to get a neutral pH, the makers usually add a base which
neutralises the acid. (Fine art and archival papers are either made with
an acid-free process, or are de-acidified, both of which cost more.) The
problem is that a bit of water will change the pH, especially in the
presence of other chemicals such as fillers and brighteners, and of
course the ink itself. Water dissolves the solids in the paper, which
affects the pH.
Also, paper is also bleached and coloured to get the right colour tone
and brightness. The bleach is acidic, the colour is dyes. There are also
fillers such as gypsum, talc, brighteners, and plastics. All these will
react with the dyes and pigments in the inks in different ways. Result:
different colours from the same ink. Professional printers will actually
formulate their inks slightly differently for different paper stock, as
when printing up a set of letterheads, labels, memo pads, posters, and
so on for a client who wants their coloured logo on every piece of paper
Bottom line: all ink will look different on different paper stock. If
you are using a new paper, make a test print, and wait a day or so to
see if a colour cast develops. If you are very serious about your
prints, do the fading tests, too, and keep careful notes. When you find
a ink + paper combo that does what you want, stick to it. And hope the
ink and paper manufacturers don't change their formulas. :-)
HTH
Reply to Anonymous
On Tue, 22 Mar 2005 08:46:48 -0500, Wolf Kirchmeir <wwolfkir@sympatico.ca>
>affects the pH.
>HTH
Good advice. Thanks!
John H
Reply to Anonymous
- 0 +
My experience with my canon i960 printer with both OEM and MIS inks is that
Kirkland photo glossy paper and the inexpensive Epson glossy photo paper
produce prints with excellent color balance and look very similar to the
canon glossy pro paper in side-by-side comparisons. The Kirkland paper is
thicker, has a smoother glossy surface than the Epson glossy photo paper,
and produces a print that looks like a photo lab print. I set the printer
to glossy photo paper and manual color for these papers and sometimes reduce
the intensity slightly if skin tones appear a bit to intense. I can not
speak to the issue of fading or longevity, but the photos I have printed and
kept in albums or in frames (not in sunlight) still look excellent after six
months. Not exactly a timeline to test archival quality, but just a
practical observation.
"John H" <notavailable@here.com> wrote in message
news:pt0141lj9odhjoagtfjqprgmcta6j75r3m@4ax.com...
> wrote:
>>> paper type
>>affects the pH.
>>HTH
> John H
Reply to BURT
You set it to "Glossy Photo Paper". Interesting. I've only been using
the "Photo Paper Pro" setting, which I believe is the suggested one for
my printers. That seems to be the only setting that sets off the highest
print resolution, as the prints take the longest to print.
> I can not speak to the issue of fading or longevity, but the photos I have
> printed and kept in albums or in frames (not in sunlight) still look
> excellent after six months. Not exactly a timeline to test archival
> quality, but just a practical observation.
And left unprotected they won't fade in your dark drawers in six months
either, unless of course, you've got toxic waste, agent orange, and a
generous dose of radioactive fallout in there along with them. ;-)
-Taliesyn
Reply to Anonymous
- 0 +
When I first bought the printer I tried side by side comparisons of epson
photo glossy, premium glossy, Canon pro, and Kirkland glossy. OEM and MIS
inks. I felt that the pro setting produced overly saturated prints. I
will try it again. Thanks for the info. Who knows what evil lurks in the
depths of the drawers in which the photos are stored? Having lived in the
same house for 40 plus years, I'm afraid to look at what we have
accumulated. It would take an archeologic dig. Agent orange or toxic waste
is definitely a possibility.
"Taliesyn" <taliesyn4@netscape.net> wrote in message
news:3ac9b0F6900naU1@individual.net...
>> that Kirkland photo glossy paper and the inexpensive Epson glossy photo
>> paper produce prints with excellent color balance and look very similar
>> to the canon glossy pro paper in side-by-side comparisons. The Kirkland
>> paper is thicker, has a smoother glossy surface than the Epson glossy
>> photo paper, and produces a print that looks like a photo lab print. I
>> set the printer to glossy photo paper and manual color for these papers
>> and sometimes reduce the intensity slightly if skin tones appear a bit to
>> intense.
>> have
> -Taliesyn
Reply to BURT
- 0 +
excuse the double post - I just ran a few test prints on Kirkland paper with
MIS inks to compare settings for glossy photo paper, photopaper pro, and a
custom setting all the way over to the "fine" setting. With an 8x jeweler's
loupe the sharpness appeared to be, if not the same, extremely close. There
was a difference in saturation that was subtle but apparent. any one of the
prints, by itself, looked great. Side-by-side, it is a matter of taste. I
would have to hold the photo up in the room in which the picture was taken
to verify which is the truest . Then, again, the truest rendition of hue
and intensity may not be the most attractive print!
>> intense.
>> have
> -Taliesyn
Reply to BURT
My local Costco has stopped carrying the Epson paper for some reason. Now they
carry only the Kodak and the Kirkland. I've not had good luck with the Kodak,
compared to the Epson, but based on what you said, I'll try a pack of the
Kirkland. I wonder who makes the Kirkland.
John H
Reply to Anonymous
I hope that's not a sign of things to come elsewhere as this Epson
Glossy Photo Paper is very valuable to me for use as greeting cards, CD
liners, booklet covers, etc. I go through about two 120 sheet packs a
year. Although it can print very good photos, I don't like the look
and feel of the paper for that use. I prefer the Kirkland. The worst
for me is the Kodak Premium Picture Paper. You mentioned you haven't
had "good luck" with it. It's not luck. It's just not very good
paper. I don't like at all the drab printed results it gives. My Dollar
Store paper prints infinitely better than this Kodak. Its only positive
is that it comes precut to 4x6 . . . . good for my test prints.
-Taliesyn
____________________________________________________________________
3rd party inks: print anything you can think of, with ink that costs
next to nothing, to impress people you don't like.
Reply to Anonymous
Hi John,
If you have any of the Kodak paper remaining, try adjusting your printer
drive to the settings suggested on the Kodak site. We have tested most
printers and drivers so when using the settings and Kodak paper the results
are very good. Go to the following site.
http://www.kodak.com/go/inkjet
Talk to you soon,
Ron Baird
Eastman Kodak Company
news:cim241tdfqp2peuf8f477edl674dcvfj4o@4ax.com...
that
is
printer
reduce
and
six
they
Kodak,
> John H
Reply to Anonymous
Greetings Taliesyn,
Just curious if you are using the suggested settings on the Kodak site for
your particular paper. Also, are you using Canon inks. If so, you should
be getting great results with that paper. Give the paper a try after
adjusting your settings. If still not good let me know and send me a sample
and I will review for you.
Talk to you soon, Taliesyn,
Ron Baird
that
is
paper,
printer
reduce
and
six
Reply to Anonymous
It is made in Switzerland. Ilford has a plant in Switzerland. Maybe
they make it?
Reply to Anonymous
Ron Baird wrote:
>Greetings Taliesyn,
Based on this question, can I assume that Kodak feels 3rd party inks are
inferior to OEM inks?
> If so, you should
>Ron Baird
>that
>is
>paper,
>printer
>reduce
>and
>six
Reply to Anonymous
Ron Baird wrote:
> Greetings Taliesyn,
> Ron Baird
Greetings Ron,
Sorry, I don't mean to slam Kodak Premium Paper but it just doesn't
perform, look or feel as good as most of my other papers.
From the Kodak website the recommended settings for my Canon iP5000 are:
"Other Photo Paper", Print Quality: "High", Color Adjustment: "Manual -
Magenta -10, and Yellow +5".... Not my usual settings, but I tried them.
The results are totally unacceptable - Strong head pass lines visible,
quite washed out, speckled (very visible dots). The only recommendation
that makes any sense is the Magenta -10, and Yellow +5 suggestion.
I've run various tests on it earlier (on an i860) and didn't like the
results very much. And today on the iP5000 I tried again. And no, I
don't use Canon inks, they're made by Formulabs. If you're about to
suggest that my inks may be in conflict, I won't buy that for a moment
as they produce great prints with all other papers - even Dollar Store!
I tried several settings with the paper and the only one that produces
the most satisfactory print is "Photo Paper Pro". At this setting the
result is still visibly poorer than the excellent result produced on my
Dollar Store paper (not my favorite paper). I know that sounds like an
insult to Kodak, but Kodak will have to get used to it as more and more
inexpensive papers arrive on the market from places like China (mine is
sold as Likon brand). The Likon print seems to have perfect contrast
(the Kodak is a bit washed out like there's a film over it), the blacks
are blacker and shows absolutely no visible print lines when the photo
is turned sideways, whereas the the Premium paper shows lines. This
Likon paper actually prints as good or better than Canon Photo Paper
Pro. It's not instant dry (24 hrs recommended), but it works great. My
preferred paper right now is Costco's Kirkland Professional Glossy. And
I do understand that this Kodak Premium paper is not Kodak's best.
As for the other settings tried (compared to the Photo Paper Pro setting):
Plus Glossy - Not acceptable - very visible print lines, speckled and
slightly more washed out.
Glossy - a bit less of all the bad characteristics of Plus Glossy.
Other Photo Paper - Do not use, the worst setting of the bunch.
I do have Canon OEM ink that I could also run these same experiments
with. But the ink I use is perfect with all my other papers - no
horizontal print lines, perfect contrast, unspeckled clarity, etc.
I really see no point in chasing my own tail any longer with settings.
I've already done these same basic tests now on two separate printers
and the results are the same. You claim it should give great results.
Maybe someone, somewhere, on some other brand printer. But my basic
tests don't agree with your generous assessment of Kodak Premium Picture
Paper. I have used Ultima (once), and from recollection I found that to
be OK.
-Taliesyn
Reply to Anonymous
Have you find many sources for Formulabs ink. alotofcrap is not a source.
Taliesyn wrote:
> Ron Baird wrote:
>> Greetings Taliesyn,
>> site for
>> should
>> sample
>> Ron Baird
> Greetings Ron,
And who do you think makes Kirkland?
> . And
> setting):
> Picture Paper. I have used Ultima (once), and from recollection I
> found that to be OK.
> -Taliesyn
Reply to Anonymous
I have an order with 88inkjets.com for several Formulabs-based
cartridges.
You said "Alotofcrap" is not a source. Is that your pet name for
Alotofthings? I thought they sold Formulabs filled cartridges
and bulk inks to Americans. Did they place you on their "Do not
deliver" list too?
-Taliesyn
Reply to Anonymous
measekite wrote:
> Ron Baird wrote:
>> Greetings Taliesyn,
>> for
Not inferior, just different.
Differences in ink chemistry will have an effect on how the inks perform
on any given paper stock. Paper and ink are both chemically rather
complex substances and mixtures of substances. There is _always_ some
chemical reaction between ink and paper.
In addition, inks and papers differ in their physical properties of
absorbency, reflectivity, adhesiveness, and so on.
Both the physics and the chemistry affect the way a given ink + paper
combination works.
The printer manufacturers give a head strat by programming the printers
to change droplet size and colour combinations for different types of
paper. But you may still have to do some manual tweaking when you change
ink and/or paper. Depends how fussy you are, I suppose. :-)
Reply to Anonymous
On Wed, 23 Mar 2005 14:53:22 -0500, Taliesyn <taliesyn4@netscape.net>
>deliver" list too?
Hold on there folks.... I get my carts from alotofthings because they
(are suppose to) have Formulabs Ink in their refills (Arrow Carts).
Are you telling me that they don't?
Now let me add that my last order from them did come with half the
carts Arrow brand which they say are filled with Formulabs ink and the
other half were Premium Imaging Products brand carts which they said,
when I called about this, were suppose to also contain Formulabs ink.
FYI, for my i960, the Arrow brand carts were the 6Y, 6C & 6M while the
Premium brand carts were the remaining 6B, 6PC & 6PM.
DW
Remove "spam" from address to email.
Reply to Anonymous
They are an immature unprofessional organization without their own web
store but promoting am eBay site that is uninformative and
unprofessional as they com and refuse to answer any questions that they
infer as a criticism.
alofofthings=alotofcrap=alotofimmaturity=Formulabs need to promote
competition unless they do not care about the small quantity purchaser.
Taliesyn wrote:
>> source.
> cartridges.
> deliver" list too?
> -Taliesyn
Reply to Anonymous
>>deliver" list too?
SUPPOSED TO CONTAIN - Doesn't alotofCRAP know. Why would the immature
idiots send you something you did not order?
>Formulabs ink.
>DW
Reply to Anonymous
- 0 +
Measekite - why such mean spirited, vitriolic name calling for a small
company you have never had the experience of doing business with? First
hand experience by their actual customers, positive or negative, is what the
newsgroup needs, not ranting by someone who has taken a dislike to their
admittedly mediocre presentation. Although I have not yet used their
product, I did purchase filled arrow cartrudges on ebay and they were at my
home just a few days later. What motivates you to try to hurt a small
business that actually sells a decent product? I would guess that the
extremely low price they charge is, in part, due to their ability to keep
the overhead low. Really good websites require either the skill to prepare
them or the expenditure of considerable money. ebay is an extremely
economical way for a small vendor to enter the marketplace. Leave the poor
guy alone, already, and just buy someone elses ink!
"measekite" <measekite@yahoo.com> wrote in message
news:Jtj0e.730$zl.122@newssvr13.news.prodigy.com...
> Taliesyn wrote:
>> Ron Baird wrote:
>>> Greetings Taliesyn,
>>> for
>>> should
>>> sample
>>> Ron Baird
>> Greetings Ron,
>> results very much. And today on the iP5000 I tried again. And no, I don't
>> use Canon inks, they're made by Formulabs. If you're about to suggest
>> that my inks may be in conflict, I won't buy that for a moment as they
>> . And
>> setting):
>> Maybe someone, somewhere, on some other brand printer. But my basic tests
>> don't agree with your generous assessment of Kodak Premium Picture Paper.
>> I have used Ultima (once), and from recollection I found that to be OK.
>> -Taliesyn
Reply to BURT
I totally disagree. After emailing them and asking questions I got a
stupid response that pissed me off. Anyway, thanks to Taliesyn, I found
a source that sells Formulabs carts, has a businesss like website,
reasonable prices, and information.
Here is a link to the site.
http://www.88inkjets.com/
Tell me what you think. At this point I do not think they sell
Formulabs Bulk ink for the Canons.
>>Taliesyn wrote:
>>>Ron Baird wrote:
>>>>Greetings Taliesyn,
>>>>for
>>>>should
>>>>sample
>>>>Ron Baird
>>>Greetings Ron,
>>>. And
>>>setting):
>>>-Taliesyn
Reply to Anonymous
I kinda wondered about that too. Seems awfully
mean spirited. I ordered a refill kit for an HP
from them some months ago. Didn't go to their
ebay site and didn't find anything particularly
bad about Alotofthings.com, not totally intuitive,
but not bad. Anyway, they shipped promptly. I've
used the black and can't tell any difference from
the original ink. I tried to fill an old color
cartridge that sat in the refrig for a few months.
, but didn't have high hopes that it would
printed right. It refused to print period,
regardless of what I did, so the jets may simply
be plugged tight after a long time or the
resistors are burned out. Anyway, I thought
filling would be good experience and didn't use
much of the color. Soon as my current color
cartridge gets low (I am watching carefully and
will stop printing if I see any missing color),
I'll try filling it and expect it will work just fine.
BTW, I only put 10 ml in my black cartridge (half
the capacity). As soon as I put another 15 ml in
it, I will have recovered my total cost for the
refill kit, and I will still have lots of black
refills.
Reply to Anonymous
Measkekite, I wanted desperately to order from Alotofthings. And I
couldn't have cared less if a grade 3 student had made their website!
If he sells Formulabs ink, that's all I need to know. I just wanted some
ink. But they refuse to serve Canadians claiming they can't give us the
same quality (fast) service they do Americans. This upset me and I
called them "Alotofnothings" for abandoning Canadians. All he had to do
was put a notice that Canadians should expect to have to wait up to 2-3
weeks for delivery, for Canada Customs clearance with possibly added
fees. I'll sign a waiver. I'll wait. I just want ink!
But your resorting to calling them "alotofcrap" is totally uncalled for.
Alotofthings at eBay has a 99.9% positive feedback from a total of 7,083
buyers (as we speak). Now why would anyone possibly believe you, a
certified non-buyer?
Joe (have I got the right person?) IS WILLING to sell you a thousand
cartridges and "gallons" of Formulabs ink if you just let him. Instead
you've chosen name calling without actually willing to do any business
with him. But then you don't shop online any way.
Message to Alotofthings: Are these the U.S. people (Measekite) you're
dying to serve at the expense of us Canadians? Well, I think you should
seriously reconsider your marketing strategies.
-Taliesyn
Reply to Anonymous
Greetings Measekite,
Not necessarily, just that the suggested settings for Kodak products used
with the drivers and with Kodak EasyShare or the One Touch options are based
on manufacturers inks. Since refillable inks are generally not documented
etc. they may vary for color, and many other factors? Might be just fine as
well, but you can count on conisistency of product with the manufacturers
products.
Talk to you soon.
Ron Baird
> Ron Baird wrote:
> >Greetings Taliesyn,
for
> > If so, you should
sample
> >Ron Baird
Reply to Anonymous
Greetings Taliesyn,
Thanks for the review. I appreciate your sharing the testing and use
results but, as you know, for someone to offer a particular setting for
general use by thousands of people, the suggested settings must have
consistency. Kodak bases its recommendations on OEM inks from the
manufacturer with a particular printer and driver. I am quite sure that if
you used those settings and that ink type, your results would be much
better. They are quite good in our labs and in review or personal
applications.
I understand controlling costs, I do too, but many believe that Kodak offers
great quality. The testing that is done on all the printers and related
drivers offered is extensive and time consuming. We do it, however, so you
can always expect good quality using the related inks and printers
associated with the suggested settings.
Ron Baird
> Ron Baird wrote:
> > Greetings Taliesyn,
for
should
sample
> > Ron Baird
> Greetings Ron,
Reply to Anonymous
Ron Baird wrote:
> Greetings Taliesyn,
> applications.
> Ron Baird
Okay, Ron, you forced my hand, er inks ...
I whipped out my non-OEM cartridges and replaced them with the
recommended OEM inks. I do have them, they're only 3 months old, kept
in a cool place for occasions just like this. I did a deep printhead
clean and ran a nozzle check to see if all was well. It was.
Again I used the Kodak recommended settings for the iP5000, exactly
as posted on the Kodak web site.
The results were a tad better than with the inks I was using (we're
being absolutely honest here, I have nothing to lose). The vertical
head pass lines were less noticeable but still there, the print was too
light (washed out) showing distracting speckles/dots.
So you can bet I ran off a print on my dollar store Likon paper for
comparison with my yesterday non-OEM ink Likon print. If I hadn't
shifted the suggested -10 M, + 5 yellow setting back to normal, the two
prints would have been identical. Both are absolutely beautiful. The
print on Kodak Premium Picture Paper is simply not acceptable, even
with Canon OEM inks. Even the paper curls and sags in all directions
after it prints and dries. I don't like that, Ron. Likon dollar store
paper keeps it shape after printing. How difficult can it be for Kodak
to get better backing?
A test print on Kodak Ultima (my settings) was excellent with Canon inks
but showed some vertical lines and graniness with non-OEM inks.
Conclusion: Kodak Premium didn't give acceptable results with even
OEM ink on my printer.
Kodak Ultima was good, though wouldn't work properly with two different
non-OEM inks. Buyer beware.
They may state on the package that this "paper works with all inkjet
printers". But the case is certainly not true with all inks.
-Taliesyn
>>Ron Baird wrote:
>>>Greetings Taliesyn,
> for
> should
> sample
>>>Ron Baird
>>Greetings Ron,
Reply to Anonymous
- 0 +
On Thu, 24 Mar 2005 12:45:27 -0500, "Ron Baird" <ronbaird@kodak.com> wrote:
>Greetings
annoying top posts
Reply to Pete
I can confirm that Costco here in Canada too has stopped carrying Epson
Glossy Photo Paper. They only had 3 boxes left in my store. Since I like
this paper for my greeting cards and CD liners, I'm stocking up. I have
two unopened boxes and some in a third. 250+ sheets should last a while.
I'm not about to pay $1 a sheet (almost) that they charge at stationary
stores compared to Costco's $32 CDN (with taxes) for 120 sheets.
For digital photos I like Costco's Kirkland Glossy.
-Taliesyn
Reply to Anonymous
Dear all,
I have a i960 Canon printer since four years and wanted to through it
away when I got it:
- The Eaysy-PhotoPrint software & supplied ICC colour profile
along with Canon PPP photo paper combination is just good for trash:
Colours are saturated and too much red.
- Do not use the printer settings proposed on Kodak's web site, they
are no good.
- The best prints = to a lab finishing print is the following:
i) I always used Kodak Premium Picture Paper.
ii) Register to the Kodak Professional web site
iii) Download the KProIJPaper_CaI960_V1 latest colour profile for
the I960 or your printer model. Follow the instructions to install it
on your computer.
iv) Install the ICC profile into:
C:\WINDOWS\system32\spool\drivers\color
v) Set the printer driver settings as indicated in the PDF file.
vi) Use the Kodak EasyShare printing software you will find free
to download on the Kodak site.
Note that I'm using Interactive Media Sales (IMS) ink refills.
"www.ims-ink.com". You can find it at COSTCO
Note that I never used other paper than Kodak's but with the Kodak PPP
paper you will get astonishing laboratory result.
Good printing!
Reply to Anonymous
Dear all,
away when I got it:
- The Eaysy-PhotoPrint software and supplied ICC colour profile along
are no good.
on your computer.
www.ims-ink.com. You can find it at COSTCO
Good printing!
Reply to Anonymous
Dear all,
away when I got it:
are no good.
on your computer.
Good printing!
Reply to Anonymous
Dear all,
away when I got it:
are no good.
on your computer.
Good printing...
Reply to Anonymous
Dear all,
away when I got it:
are no good.
iii) Download the KProIJPaper_CaI960_V1 latest colour profile for the
I960 or your printer model. Follow the instructions to install it on
your computer.
vi) Use the Kodak EasyShare printing software you will find free to
Good printing!
Reply to Anonymous
Dear all,
away when I got it:
are no good.
on your computer.
Good printing!
Reply to Anonymous
There are 2127 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1080 and 1200p monitors
By ssddx, 1 day ago:
hello again... remember that an actual screenshot comparing the two would be useless...
Best offers
Top experts
