So, another noobish question, but I've heard that it's a good idea to have the Motherboard chipset and the GPU from the same company, for example, you should pair an nVidia GPU with a MoBo that has an nVidia chipset on it. Likewise, you should pair an ATI GPU with a MoBo that has an ATI chipset.
Is there any truth to this, or is it just speculation? What difference would/could it make?
Thanks
It really depends. If your asking about putting a Nvidia GPU in a crossfire mobo it want work. If your asking about putting a ATI GPU in a SLI mobo it may not work correctly. If your asking about putting an Nvidia GPU in a mobo with an ATI chip set its may not work correctly. If your asking about putting an ATI GPU in any non SLI mobo with a Nvidia chip set it should work fine.
If your wanting to put a PCI GPU in an mobo with an Intel chip set from the 82845 up then it should work fine. If your wanting to put a PCI GPU in a mobo with an Intel chip set lower that the 82845 then your mobo chip set will fry.
Wow...
ATI, VIA, Nvidia, SIS,ULI,Intel,...
They all do chipset. Chipset buses have to comply with standard. PCI standard, AGP standard,PCI-e standard.. All chipset should follow those guide line if they dn't want to have problem with compatibility. Same for video card. ATI and Nvidia make videocard. And chipset too. But what about VIA or SIS?? You think that ATI and nvidia are dumb enough to make their chipset/video card compatible only with them, flushing away lot of video card sale to people that has VIA or SIS chipset??
You can put any video card with any chipset. while you may get better performance between same brand(because they obviously know what to do to optimize thing on their hardware), you are not supposed to have any incompatibility between brand, because they all comply to standard. It would be suicidal for, let say, nvidia to prevent third party hardware working on thieir. It would give them bad press, and lot of company wont choose a product with them fearing future problem. Hey, they don't make chipset and video card only for gamers.. Office computer does need a something to display on the screen.
The only exception is either crossfire or SLI. They are not hardware stuff but software stuff. That's the drivers that detect the chipset and allow or prevent these mode to work or not (not that I said "these mode" and not these video card.... if you have 2 ATI video card in a sli motherboard, then you will have 2 video card able 2 run 4 screens...you simply won't have cooperation mode between video card(unless you hack the driver)). Happily, hacked drivers allow to run crossfire or sli on any motherboard with any chipset that has 2 PCI-e graphic slot...
to put is simply, you can buy any board, with any chipset and connect any video card and it should work. If it dont, then it is the motherboard maker that screw up thing with their design or BIOS.
