Hi guys,
I've just put together a brand new system and am having some heat issues with it. Here's the spec first of all:
Case: Gigabyte 3D Aurora (1x front 120mm intake fan, 2x rear 120mm exhaust fans all at 1000rpm)
Mobo: Asus M2N32-Sli Deluxe (BIOS 0302)
CPU: AMD 4800X2 using stock HSF and Akasa pro-grade 5022 thermal compound
RAM: 2GB Corsair TwinX DDR2 6400 C4
GFX: Leadtek Geforce 7950GX2
PSU: Xclio X14 600W (2 exhaust fans)
HDD: Western Digital 320GB
SND: Soundblaster Audigy 2 ZS
For reference, my room temperature is about 25-28C (a hot attic room ) and I should mention I've not had any stability problems so far (after lots of game playing and 8.5hrs stress testing on prime95).
At idle:
CPU - 42-45C
Mobo - 44C
GFX - 60-65C
Under load:
CPU - 58-62C
Mobo - 51C
GFX - 70-80C
I'm unsure as to which temperatures to rely on for the cpu as well - the bios, PC Probe II and AI Booster all report the same value, but Everest and Speed-fan report another one (37 idle, 60-65 load) - this one will sit constantly at 37 then when prime95 is run instantly hit 60, so is this the on-die sensor???
Taking the side off and pointing a desktop fan at it helps considerably (Idle: CPU - 33C, Mobo - 34C, GFX - 50C) but I really thought the setup would have been enough to keep it cool on its own
I am holding out some vague hope that the temperature readings are screwed - as it certainly feels cooler than my old PC even though its reporting much higher temperatures...
Does anyone have any ideas on how to bring these temperatures down a bit? I'm thinking about grabbing an Arctic Cooling Freezer 64 pro or a Scythe Miné but will this make a big enough impact?
Thanks in advance,
Stu
At idle:
CPU - 42-45C
Mobo - 44C
GFX - 60-65C
Under load:
CPU - 58-62C
Mobo - 51C
GFX - 70-80C
Thanks in advance,
Stu
