Ok so currently, and for the past 4 years I've been using this setup:
AMD Athlon XP 1700+
1GB Generic pc2100 RAM
ECS K7S5A Mobo
GeForce FX 5200 128MB gpu
Now, with games in mind, I'm desperate to build a new PC. If it helps, I want to run Everquest 2 with good graphics and performance balanced. Here's what I've picked out so far (keep in mind, I know about all the new chips coming out soon).
AMD Athlon X2 3800+
Asus A8N-SLI ATX mobo (Not deluxe or premium..)
1Gb Corsair XMS Pc3200 RAM
eVGA Geforce 7900Gt 256MB GPU
Also, I'd like to add that I came across a concept of building using Intel D 805 2.66 Ghz CPU w/ a compatible mobo and Corsiar 1Gb Value Select Ram, and same graphics card for about at least $100 less. I would like to know if this would be a better bang for my buck route, or would AMD be better for gaming or perhaps increase the longevity of the system. I know S939 is beng pushed away by AM2, but currently no AM2 CPU's exists that fall in my price range..
Thanks for any comments/suggestions.
AMD Athlon XP 1700+
ECS K7S5A Mobo
AMD Athlon X2 3800+
