real low 3dmark06 score with a great system, PLZ HELP!!
  • Graphics Cards
  • Crossfire
  • ATI
  • Graphics
June 13, 2006 5:40:31 AM
my specs=
amd fx-60
4gigs pc 3200 ram with heatsinks on them
1 ati x1900 crossfire edition card
1 ati x1900xtx card
2 74g raptors
DFI mobo
1k power supply
and all that with a score of 6354 in crossfire mode? is that what its supposed to be?
any help would be appreciated thnx
More about : real low 3dmark06 score great system plz
June 13, 2006 7:35:33 AM
Its just a benchmark. How well do your games run.
June 13, 2006 7:37:27 AM
You sure you actually got it working in crossfire mode? I don't know much about ATI cards but check in the ati control panel that crossfire is configured.
Also, check your quality settings, at high quality all cards perform rubbish.
Try the latest vga driver.
I got around 4500 3dmark06 score for a 3800x2 and 7800gt so although your result is a little on the low side, it's not drastically low.
June 13, 2006 10:32:46 AM
What OS are you running? 4gb is a total waste. Try running it with 2gb instead, and you should see some kind of a difference.
June 13, 2006 12:42:07 PM
6354 is low for 1 of those video cards, are you sure your running in crossfire mode?
I get 6415 with 1 7600GT and a Sempron64. Something aint right.
June 13, 2006 3:43:34 PM
What's your processor score?
3dMark 2006 scoring is HEAVILY dependant on the CPU. Dual core CPUs will give a huge scoring advantage over a single core, even if the single-core machine is the faster gamer in reality.
June 13, 2006 4:31:00 PM
Well since the FX-60 IS dual core that can't be his problem. I would also check whether your video cards are actually running in crossfire mode. My system (in my sig) is able to get over 7500 stock so something is definitely wrong, the only difference is that I'm only running 2 gb of ram.
June 13, 2006 5:03:58 PM
He said 3DMark06, not 05.
June 13, 2006 5:25:00 PM
I see that now, my bad.
June 13, 2006 5:46:59 PM
Go down to two sticks of RAM and run them in command mode 1T.
Also make sure Crossfire is enabled, and if it is, try the benchmark with one card out.
June 15, 2006 8:26:24 PM
Well my score must be real shit then. But i have a farily decent spec - my system still is sweet as a nut and runs games/apps real good:)
Check:
What do you guys think of this then?
June 15, 2006 9:21:03 PM
That is a good score for a 7900GT and 3700+ with no overclocking.
