Power and grapics cards???
  • Graphics Cards
  • Power
  • Graphics
  • Product
June 13, 2006 6:46:46 PM
I want to upgrade my AGP graphics card, and was wondering what the best card I can get is, since I only have a 350W PSU?
(I have a P4 2.8GHz, 2 sticks of 512MB RAM, a 120Gb Harddrive, 2 optic drivers using the power as well (dunno if thats relevant))
More about : power grapics cards
June 13, 2006 7:11:37 PM
X800XL, 6800GS, X800GTO will be fine. Those cards fit your system specs nicely.
June 13, 2006 7:32:34 PM
I would agree with prozac. The 6800GS is hard to find and usually costs more than the X800GTO. I'm not sure that it is worth the extra cost. Newegg has a pretty good deal on the X800GTO right now if you don't mind doing rebates:
http://www.newegg.com/Product/Product.asp?Item=N82E1681...
Some of the Sapphire GTOs can be unlocked to 16 pipes if you are into that kind of thing. It doesn't make a huge impact but it gets the card up to about equivelant with an X800XL.
Another possibility is the X850Pro. It is a little more expensive than the GTO and performs about the same as an X800XL. The X850Pro also has a rebate:
I have an AGP Sapphire X800GTO in my Pentium 4 2.8c system. I am pretty happy with it. I upgraded from a 9800Pro around 6 months ago. It nearly doubled my 3D benchmark scores after I unlocked it and slightly overclocked it.
June 14, 2006 2:10:28 PM
Nice, now i wanna buy it... how exactly do you unlock it?
June 14, 2006 3:13:48 PM
Im in the UK, where is the best place to buy from?
June 14, 2006 6:07:37 PM
There are two ways to unlock the pipelines. You either have to find a compatible bios that has 16 pipes enabled instead of 12 or you have to modify a copy of the bios that is on your card. Modifying it involves opening it up in a hex editor and changing one of the bytes. Once you have one of these two bioses, you have to boot into DOS from a floppy or something like that and flash you video card with the new bios.
If you have one or are getting one, I can give you setp by step instructions on how to do it.
ghetom,
I don't have any idea where you could get anything in the UK.
I live in the U.S. Sorry I can't help you.
