Very nice but I have to ask, did you really need a triple rad for just your cpu or are you adding gpu water blocks later?
I have a similar system in an Armor but I've also got the nv78sli dual gpu water block from danger den (same cpu block and pump) but I've gone with a 2 x 120mm rad inside the case taking up 6 drive bays in the front behind the mesh covers. It took a little modding with a couple of L brackets and a drill but it keeps the rad inside the case, didn't like it hanging out the back on my old Tsunami case, which is why I got the armor.
