Hey Darthkir,
From what I can read, you might want to take a look at your power supply.
ALWAYS remember that ESPECIALLY wehn your running SLI, the power supply must be able to give out 30 amps on the rail that gives power to the cards. If the power fluctuates even 1/2 a volt, you got trouble.
Even though your cards don't need external power, you may want to look at the power supply.
Consider this........when you want to buy a new video game.......let's use Doom 3 for example..... and you look at the computer specs to see if your rig will be able to measure up.......the specs they give are ABSOLUTE minimum to run the game with no eye candy on, but they don't tell YOU THAT......if you try to up the toys for the game.....the game will stutter, freeze, cough , choke....you get the point.
When I built my rig 4 months ago, I knew I would be going SLI eventually, plus I also knew what hardware would be inside. I went with a 600 watt Seasonic S12. And it also indicated on the box that it was "SLI" nvidia certified. Basically what that means is that it meets the power demands to run your rig AND it will also have 2... NOT 1 ... but 2 power dongles to supply power to each vid card.
So if you decide to look for a more powerful power supply, look for one that has 2 - 12 volt rails. If it does, you know that it will be able to run what you need.
Hope this helps man, good luck
My system specs
Antec P180 PerformanceSeries mid-Tower
Asus A8N32 SLI mobo (bios version 1103 V02.58)
AMD Athlon 64 X2 4800+ Toledo Core, 2 X 1mb L2 cache (amd drivers w/MS hotfix)
2 gigs of Corsair TwinX3500LL Pro @ 437Mhz 2-3-2-6-1T
2- BFG 7900 GT OC 256mg in SLI (nvidia driver version 84.21)
Western Digital RAPTOR 74.3 gig 10-K rpm HDD for XP & apps
Maxtor SATA II 250 G HDD for gaming, movies, MP3's
Maxtor SATA II 250 G HDD for document backup (unplugged)
52 X sony cd rom
Plextor 708A DVD/cd rom
SeaSonic S12 600 watt power supply
Logitech Z 5500 digital 5.1 THX Surround 500watts
RealTek 97 onboard digital sound
