I already tried writing this once nice and detailed, but, ironically, my computer crashed while I was doing it. :x
Briefly: my computer hardlocks (totally stops working—even sound stops) randomly and I can't figure out why. (I've been trying to get help here, too, but to no avail.)
I've done a Memtest and passed perfectly. I've replaced my PSU and my video card and it's had no affect. It doesn't seem to be load- or temperature-related (like when it crashed while writing a post for this very forum!).
My power supply reads 11.52V on the +12V according to ASUS Probe, a diagnostics program that came with my ASUS motherboard.
Here's my system's setup:
- AMD Athlon 64 3000+ (Newcastle)
- ASUS K8V SE Deluxe K8T800
- 1GB Corsair PC3200 RAM
- BFG Geforce 6600
- Thermaltake TR2 W0070 ATX 430W power supply (see here)
- Maxtor DiamondMax 10 250GB SATA w/16MB cache
- Maxtor 80GB EIDE
- NEC ND-3500A DVD±RW
- Pioneer DVD-ROM
- Windows XP Pro w/SP2
Could it be my XP install or my SATA hard drive? I swear the problems cropped up when I installed the SATA hard drive and put XP (with SP2 "slipstreamed" into it) on it. Could the low voltage be the problem? On two power supplies in a row? (Both 18A on the +12V.)
- BFG Geforce 6600
- Maxtor 80GB EIDE
- Pioneer DVD-ROM
Please help! I have no idea what to do now...
Thanks.
It sounds to me like it could be a Windows problem. Memtest doesn't use Windows, therefore no problems. 12V is ok. a 5% variance is okay, which means 11.4v - 12.6. Posting in the Forum isn't stressful, so theres no load involved. I would think about a reinstall, minus the slipstreaming. GL
It could be a hard drive problem, it happened to me once. Computer kept crashing every once in a while (actually quite often) especially when doing virus scans and stuff. Try doing a few virus scans and/or defragmenting and if you're getting a pattern when you do that ie: it locks up in the same general place every time, then it's most likely your hard drive.
Also, the low voltage could be a problem as well. PSUs are allowed to be within 10% of the rated specs, but being closer to what it says is always better for your equipment. It might have slipped down below the 10% mark and caused damage to your hardware, again possibly the hdd.
If I can find the disc, I might start with a "repair" installation. I'd like to avoid re-installing everything, as you can imagine.
Forgot to mention that, on my old video card, sometimes when I rebooted I would have the following error message:
Quote :
Problem report: The NVIDIA System Sentinel is reporting that the NVIDIA-powered graphics card is not recieving sufficient power.
To protect your hardware from potential damage or causing a potential system lockup, the graphics processor has lowered its performance to a level that allows continued safe operations.
But not always. Maybe 1/8 times. New video card hasn't done that yet, but I just put it in last night.
I did a surface scan and defrag with no problems. So if it's a hard drive issue, it must not be a specific part of the discs themselves.
Quote :
I've checked it while in WoW, and even the graph of my voltage shows only minor, occasional dips—less than 0.10V of variance.
