Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Mixing different manufacturers IP phones on a Mitel VOIP n..
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Mixing different manufacturers IP phones on a Mitel VOIP n..
Archived from groups: comp.dcom.voice-over-ip (More info?)
I am going to be implementing a Mitel 3300 switch, and am looking into
IP phones. Our vendor is telling us we can't use anything but Mitel,
but I thought protocols were standardized so any IP phones would work.
Is this not correct?
thanks,
Hal
Sponsored Links
> thanks,
> Hal
IP "phones" are really built in ATA (analogue telephone adapters), and
different systems use different protocols. Of course they want to sell
you their brand of h/w, but if you ever want to dial someone who does
NOT have an IP phone, you'll have to use your vendor's systems.
Reply to Anonymous
hal@nospam.com wrote in news:qqf841p2hamul8a9840pj2o8eforb7lnnl@4ax.com:
Nope, VoIP is a generic term to mean that voice data is sent over an IP
network. There are several propreitary VoIP protocols. If you want an open
standard, ensure that your system supports SIP. SIP protocol is supported
by most Internet VoIP systems.
Reply to Anonymous
Or H.323
Andreas Sikkema
Reply to Anonymous
Rick Merrill <rick0.merrill@gmailNOSPAM.com> writes:
> You are defining it in a equivalent way: An ATA just runs a analog to
> digital conversion for analog phones. Your "digital" phones convert
> analog voice directly to digital. six of one, half a dozen of the
> other, or whatever makes you happy.
There is a very important difference. ATA's use ratty old 4-wire to
2-wire hybrids which mix the incoming and outgoing signals together.
The phone then uses another hybrid to un-mix those two signals. The
result is two echo-inducing, frequency response limiting hybrids in
your talk path.
A real voip phone has no such nonsense. In fact some of them (at
least the ones that do g.722-wideband) probably even have earphones
and mouthpieces rated to twice the normal phone frequency response.
There is a noticeable improvement in the sound quality. Of course, it
is only usable when talking between two phones that can do similar
wideband speech.
-wolfgang
Reply to Anonymous
> > thanks,
> > Hal
No, an ATA, is a specific device to connect a POTS telephone (more
likely a fax machine/modem/coin operated phone/etc) to a VOIP network.
All that is required is that the phone and PBX understand the same
protocol. Which is only likely to be the case if the latter only
speaks some proprietary protocol.
Either the phone will work or it won't. Connecting to a non IP phone
involves a PSTN interconnect somewhere. But that could be anywhere
on the planet.
Mark Evans
St. Peter's CofE Aided School
Phone: +44 1392 204764 X109
Fax: +44 1392 204763
Reply to Anonymous
There are 719 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
