News
AMD and Intel supported on same motherboard
Published on March 12, 2005
Hexus.net has a post and pictures about ECS, which exhibits at CeBit its ECS PF88, the first mainboard to support both Intel P4 AND AMD Athlon 64 processors. Read more
Nforce 3 to come in PCI Express flavour
Published on March 26, 2004
Nvidia is putting its Nforce 3 chipset on the PCI Express. Read more
Microsoft ships first post-beta 2 build of Vista
Published on June 27, 2006
Late Friday, Microsoft shipped Windows Vista build 5456, its first post-Beta 2 version of the next major Windows release. Read more
TSMC and UMC expect to post strong growth in second half
Published on May 10, 2005
Taiwan Semiconductor Manufacturing Company (TSMC) and United Microelectronics Corporation (UMC) expect to post strong growth in the second half of 2005, as the market is showing signs of a rebound, market sources said. Read more
Latest Reviews & Articles
Radeon HD 4870 X2: Four Cards Compared
Published on November 19, 2008
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Published on November 18, 2008
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
The Hardware Behind Overdrive
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
How To: Get A 4 GHz Dual-Core For $120
Published on November 17, 2008
Intel’s 45 nm Core 2 serious is known to boast substantial overclocking margins, and the entry-level E7200 with 3 MB L2 cache costs less than $120. We'll show you how to get close to 4 GHz from this little gem. Read more
  Tom's Hardware Forums » Motherboards & Memory » Asus » Asus post reporter problem
Word :   Username :
Bottom
Author
 Thread : Asus post reporter problem
Profile: stranger
More Information
I have an Asus A7N8X-E Deluxe motherboard and an AMD Athlon XP 2600+ processor(barton core). Now the problem is that I keep hearing the post reporter lady saying: "System failed cpu test!" in an endless loop, and the thing is that my computer runs smoothly, I don't get any errors in windows or linux. I don't know what to do anymore, it drives me crazy, to stop it I had to mute the master volume control on the onboard soundcard.
Please Help!!!!
Related Product
Profile: journeyman
More Information
never ever ever ever heard of that before.....ever........is it right away when you boot or when u get into windows?....weird....never ever.....
Profile: journeyman
More Information
when u boot go into bios and up the cpu core voltage might work.....
Profile: stranger
More Information
Well the cpu voltage is set on auto in the bios, but the bios automatically sets the cpu core voltage at 1.70V which is higher than the normal athlon xp with barton core (it must be 1.65V). The thing is that even if I set the cpu core voltage manually at 1.65V the cpu volatge is still 1.70V in both windows and the bios, but that didn't cause any troubles until now.
Oh and I hear the message "System failed cpu test" when the computer boots and when I'm in windows, it doesn't matter, but the computer runs fine. I just don't get it. What's wrong. It must be something wrong.
Profile: stranger
More Information
Profile: Forum Veteran
More Information
Well, if it bothers you to hear it, should be able to shut off the speech POST in the bios.
Bios settings differ, but mine is located under Advance > I/O device config.
I know I run mine turned off, that ladies voice drives me up the wall. :lol:
Profile: newbie
More Information
Razvanz, Just turn off asus post report . I have built at least 20 computers using the A7N8X-E deluxe and it all depends on the power supply and the motherboard . Most of them overclock by .03 to .05 volts and cause it to error but the system is fine and you do not have a problem . My second computer is a xp 3000 on a A7N8X-E deluxe and it will error everytime I boot it if I leave speech post report on but it has run fine since that motherboard first came out .
Profile: stranger
More Information
The Asus post reporter was turned off in the bios but I could still hear the lady's voice telling me that message so I've tried something else: I've isolated my motherboard from the chase and it seems to have worked for the moment. I can't hear the post reporter lady anymore, at least for now. I will post again if it comes up after a while.
Profile: stranger
More Information
Google Ads
