It is right on the frequency: 3800+ runs at 2.4GHz, that is 200MHz with 12x multiplier. 200MHz is the base frequency form which CPU, HTT and memory clocks are derived through PLLs.
Anyway Nero isn't an hardware test utility, use CPU-Z if you want detailed and exact hardware infos.
