Tom's Hardware > Forum > Computer Peripherals > Printers > Problem with Ink Refill for HP 2110 MFD Printer
Forum Computer Peripherals : Printers - Problem with Ink Refill for HP 2110 MFD Printer
Archived from groups: comp.periphs.printers (More info?)
I refilled the black ink cartridge on my HP 2110 printer. I worked great
that day.
Turned the printer on the next day and the LCD panel displayed error
message: check the ink cartridge
and the printer would not print.
any suggestions?
Mike
Sponsored Links
I used the software clean the print head routine, removed replaced cartridge
but same error message.
Mike
"Mike" <wxyz09@yahoo.com> wrote in message
news:NNA3e.4130$pU5.2327@trnddc06...
>that day.
> any suggestions?
> Mike
Reply to Mike
Assuming that the cartridge is not damaged or improperly filled (PSC
machines can detect high temps on firing resistors which indicate a low
ink condition, In your case it may be a small pocket of air trapped in
the nozzle area) You can try to force a Resistor ID reset:
http://www.weink.com/ecom/support/technotes/tsg01.htm
Reply to Anonymous
- 0 +
Thanks for the useful link but I got rid of the psc 2110 and bought a psc
2355.
I concerned about the 2355 because the in cartdriges appear small than the
ones in the psc 2110.
Mike
"WeInk_TechSupport" <inksupport@weink.com> wrote in message
news:1112499070.572628.175400@f14g2000cwb.googlegroups.com...
Reply to Mike
There are 2 sizes of cartridges for Black and Color:
#94 Black 11 mL
#96 Black 21 mL
#95 Color 7 mL
#97 Color 14 mL
I noticed that the #96 black is not listed as a re-order item for this
printer, so it may only accept #96 cartridges, or it could be that they
are just not being promoted for this printer.
John Mills
WeInk.com support
Reply to Anonymous
- 0 +
I'll check out #96.
Mike
news:1113355281.341119.276290@o13g2000cwo.googlegroups.com...
> #94 Black 11 mL
> #96 Black 21 mL
> #95 Color 7 mL
> #97 Color 14 mL
> John Mills
> WeInk.com support
Reply to Mike
Are you still hawking?
Mike wrote:
>I'll check out #96.
>Mike
>>#94 Black 11 mL
>>#96 Black 21 mL
>>#95 Color 7 mL
>>#97 Color 14 mL
>>John Mills
>>WeInk.com support
Reply to Anonymous
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
