Building new comp and wanting your advice
thanks in advance
Processor: AMD Athlon 64 X2 Dual-Core Processor 3800+ Socket AM2 (89W) ADA3800CUBOX
http://www.amdcompare.com/us-en/desktop/details.aspx?opn=ADA3800IAA5CU
MB: Asus M2N32-SLI DELUXE nForce 590 SLI Sempron/Athlon 64(FX)(X2) SktAM2 DDR2 ATX Motherboard w/Audio, Dual Gigabit LAN, RAID/Serial ATA
Memory: Corsair TWIN2X2048-6400C4 2GB Kit DDR2-800 XMS2-6400 Xtreme Performance Memory
Video Card: XFX PV-T71U-ZDF9 GeForce 7950 GX2 Xtreme 520M PCI Express 1GB DDR3 Video Card w/TV-Out & DVI
What is the difference between these 3800+ processors & what does it mean? The diff. i see is VOLTAGE, MAX. TEMP, THERMAL POWER what does this mean?
http://www.amdcompare.com/us-en/desktop/SideBySide.aspx?opn=ADA3800IAA5CU&opn=ADO3800IAA5CU&opn=ADD3800IAT5CU
and what is the difference between the Orleans core and the Windsor core is one better than the other?
Sorry for all the questions
Thanks again
thanks in advance
Thanks again
