Hello to all,
I built a pc a couple of months ago with all parts (specs below) from Newegg.com. The problem that I am having is a hang up that renders the pc useless until manually rebooted.
It does not matter what I am doing at the time (Excel, AutoCAD, HL2 or just at the desktop moving files) and it could take two minuets or two hours for the symptoms to occur.
The symptoms:
1 – While moving a file or folder the folder hangs.
2 – The minimize, maximize & exit buttons do not respond, they will not even show as depressed.
3 – The keyboard stops responding (ctrl+alt+del, windows key) nothing works.
4 – The mouse stops responding.
5 – The pc stops responding completely.
6 – Single press of the power button on case that will normally soft shut down does not respond.
7 – Power button on case must be pressed for four seconds to do a hard shut down.
There is no recovering from this the pc must be hard shut down. Upon restarting I get no errors and the event viewer gives no indication of error.
Measures taken:
1 – Replaced USB mouse and keyboard with ps/2.
2 – Ran Memtest86 once for 12 hours and a second time for 26 hours with no errors.
3 – Checked PSU voltages with ASUS & Corsair tech support.
4 – Updated bios and reformatted/reinstalled XP.
5 – Have tried multiple device drivers/bios for MB & VGA
6 – RMA the video card reformatted/reinstalled XP installed new card with current drivers from NVIDIA.
7 – RMA the motherboard reformatted/reinstalled XP installed current drivers from NVIDIA.
8 – Replaced RAM with (Kingston) friends RAM.
9 – Beat my head against the wall!
Specs:
OS – Microsoft Windows XP Pro sp2
MB - ASUS A8N-SLI NF4SLI 939 – Replaced 06-16-06
PSU - TT W0101RU 550W RT
CPU - AMD A64 X2 4400+ 2.2G 939 2x1MR
MEM - 1Gx2 CORSAIR TWINX2048-3200C2PRO – Replaced with Kingston Ram 06-17-06
VGA - EVGA GF 7900GT 256-P2-N569-SG – Replaced 06-04-2006
HDx2 - WD 10,000RPM 8MB WD740GD - SataRaid = 0
Audio - Sound Blaster Audigy 2 ZS PCI OEM
Any suggestions would be greatly appreciated.
Thank You,
Tim W.
The symptoms:
Measures taken:
Specs:
Thank You,
Tim W.
