Archived from groups: microsoft.public.windowsxp.basics (
More info?)
To stop winmgmt...
Start | Run | Type: cmd | OK |
When a command prompt pops up |
Type: winmgmt /kill
Hit Enter
winmgmt.exe = Windows Management Instrumentation (WMI)
Runs under SVCHOST.EXE.
C:\WINDOWS\system32\svchost.exe -k netsvcs
C:\WINDOWS\system32\dllcache\winmgmt.exe
C:\WINDOWS\system32\wbem\winmgmt.exe
To see if WMI is running, if you have XP Pro...
Type: tasklist /svc
Hit Enter
Under one of the svchost.exe you should see winmgmt
To see if WMI is running, works with Home and Pro...
Type: net start
Hit Enter
Do you see Windows Management Instrumentation listed??
Courtesy of Kelly T. @ http://www.kellys-korner.com/
[[Windows Management Instrumentation - WinMgmt could not initialize the core
parts
Go to Start/Run/CMD and then run each of these hitting enter after each:
winmgmt /clearadap
winmgmt /kill
winmgmt /unregserver
winmgmt /regserver
winmgmt /resyncperf
This may or may not repair the repository but will re-install wmi into the
registry.]]
Hope this helps. Let us know.
Wes
In news:AF4A7EA6-625E-401F-A132-21B8AF76D8D2@microsoft.com,
Marty <Marty@discussions.microsoft.com> hunted and pecked:
> Thanks Wes for the info, but I do have Windows Management
> Instrumentation listed there, so I can not turn it off. I have
> re-installed (up-dated) XP but have the same problem.
> How can I activate this Windows Management Instrumentation feature.
> Regards
> Marty
> "Wesley Vogel" wrote:
>> Start | Run | Type: services.msc | OK |
>> Scroll down to and double click: Windows Management Instrumentation
>> | Click the Stop button | After WMI stops click OK | Close Services
>> and follow the rest of the instructions
>> Error Message: Windows Management Instrumentation (WMI) Might Be
>> Corrupted
;319101]http://support.microsoft.com/default.aspx?scid=kb;[LN];319101
>> Wes
>> In news:32A8B1EA-FF5D-4AE4-B220-D1501C713C8C@microsoft.com,
>>> I have a problem to turn on my firewall, XP system.
>>> With the error WMI may be corrupt.
>>> I have read the article Q319101 & in the resolution No5, I do not
>>> have the information on Windows Management Instrumentation, so I can
>>> not 'stop' it. I have tried to reload XP & all was fine, except this
>>> problem.
>>> I am also having problems trying to load SP2, but that is another
>>> issue. Please advise how I can get WMI working.
>>> Thaks
>>> Marty
